Hey guys, I recently bought this GTR and I'm not in a rush to sell it, I love it. I'm just putting it up for sale merely as an expression of interest, an exercise out of boredom if you will. If it sells, I'll move on, if not I'm completely happy to keep it :)
The engine was built by Gavin Wood on the Gold Coast, the mods are as follows:
CP Pistons
Eagle Rods
Tomei 270 cams
Springs/Retainers
N1 turbos with HKS actuators
Full custom tucked 3.5" exhaust and high flow cat made by Fabulous Fabrications (beautiful work) along with custom Hot/Cold cooler pipe.
Intercooler
Haltec Platinum Pro ECU
Bilstein/Eibach strut/spring combo
Cusco Swaybars
Cusco 1.5w rear diff, fully rebuilt and new diff bushing installed with newer (and slightly larger/stronger) R33 half shafts
Ikeya Formula front and rear upper control arms.
HICAS delete.
Desmond Regamasters in 17x10 + 20 wrapped in near new Federal 595 RSR's
The car made 385hp at all four on 18 psi and at a very rich tune of 11:1 up top. If I keep it, it'll be getting a retune shortly for more boost and a little less fuel, but it's quick as it is.
Aircon is cold, chassis rails are straight, no rust, this is a clean GTR :)
2 minor issues, the passenger side dash vent is missing (previous owner broke it trying to install a cup holder) and it needs new coil pack connectors and possibly coil packs. The coil issue will be taken care of prior to sale and I can chuck a vent in it, I just haven't found one for sale yet.
$21,000 ono
Will entertain the thought of trades, just depends on what I'm being offered but send your offers through anyway, it can't hurt!
0401029817
https://www.sau.com.au/forums/topic/437696-r32-gtr-forged-motor-mods/
Since listing for sale the car has had
New coils (old coils were fine, misfire was being caused by a boost leak thanks for a faulty coupler)
Service in the last 100km
Brake rotors machined and pads linished, brand new pads
Replaced coupler to get rid of boost leak
The car is ready for its new home
It's an 89 Grant, yes I have a dyno graph floating around somewhere.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
