Hey guys, I recently bought this GTR and I'm not in a rush to sell it, I love it. I'm just putting it up for sale merely as an expression of interest, an exercise out of boredom if you will. If it sells, I'll move on, if not I'm completely happy to keep it :)
The engine was built by Gavin Wood on the Gold Coast, the mods are as follows:
CP Pistons
Eagle Rods
Tomei 270 cams
Springs/Retainers
N1 turbos with HKS actuators
Full custom tucked 3.5" exhaust and high flow cat made by Fabulous Fabrications (beautiful work) along with custom Hot/Cold cooler pipe.
Intercooler
Haltec Platinum Pro ECU
Bilstein/Eibach strut/spring combo
Cusco Swaybars
Cusco 1.5w rear diff, fully rebuilt and new diff bushing installed with newer (and slightly larger/stronger) R33 half shafts
Ikeya Formula front and rear upper control arms.
HICAS delete.
Desmond Regamasters in 17x10 + 20 wrapped in near new Federal 595 RSR's
The car made 385hp at all four on 18 psi and at a very rich tune of 11:1 up top. If I keep it, it'll be getting a retune shortly for more boost and a little less fuel, but it's quick as it is.
Aircon is cold, chassis rails are straight, no rust, this is a clean GTR :)
2 minor issues, the passenger side dash vent is missing (previous owner broke it trying to install a cup holder) and it needs new coil pack connectors and possibly coil packs. The coil issue will be taken care of prior to sale and I can chuck a vent in it, I just haven't found one for sale yet.
$21,000 ono
Will entertain the thought of trades, just depends on what I'm being offered but send your offers through anyway, it can't hurt!
0401029817
https://www.sau.com.au/forums/topic/437696-r32-gtr-forged-motor-mods/
Since listing for sale the car has had
New coils (old coils were fine, misfire was being caused by a boost leak thanks for a faulty coupler)
Service in the last 100km
Brake rotors machined and pads linished, brand new pads
Replaced coupler to get rid of boost leak
The car is ready for its new home
It's an 89 Grant, yes I have a dyno graph floating around somewhere.
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
