$6,000 FIRM !!
Series 3 Hcr32 4door gtst factory rb20det, automatic
Pick up in Eastern suburbs, Brisbane, Queensland.
Rego runs out on Saturday 18th Jan 2014.
HER324 plates are not included.
COMES WITH RARE REAR SPOILER WITH BRAKE LIGHT AND FRONT LIP AUTO SPOILER!!
List of mods :
- front mount intercooler
- drift blow off valve
- boost controller
- boost gauge
- 3 " dump pipe exhaust system with a hurricane cannon tip
- Brand new alloy radiator
- Strut brace
- Original rear wing with brake light
- Rare front lip auto spoiler with wiring
- Near new tyres all round
- Rims have had a fresh respray
- Tinted windows
- Low king springs
Other things to add to description:
- Fusion alarm system
- 2 keys, one original one cut, both with a remote
- Pink dash lights
- Purple tapper covers
Hard to come across a 4door in such good condition
Looking to sell asap as I have another car in mind.
Immaculate interior
Female owned
Non smoker
Selling unregistered as is, may provide RWC
Edited by her324
https://www.sau.com.au/forums/topic/437701-1993-hcr32-4door/
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
