Hi to everybodey in here ..
Im new in this forum and would like to introduce my self first befor talkin about the problum that Im facingwith my car, my name is yousif alzayani and from kingdom of bahrain. I owned a drag race nissan z32 with rb30/rb26 setup. the car produce 1200+whpand my personal best is 7.1sec@299km the run strong but recently im facing problums with the head studs the rb25 head studs couldnt hold the power that I got In my setup when I run the over 30psi the head is lifting, so I decided to move forward with rb26 head studs and I drilled the deck but couldnt solve the problum this time the block craked and I think its because of the drilling.anybody fcaced this problum guys im talking to the hi hp guys I need some help if anybady got it.
Here some pic of the car :post-132008-0-08488800-1389908401_thumb.jpgpost-132008-0-92961800-1389908420_thumb.jpgpost-132008-0-65408700-1389908460_thumb.jpgpost-132008-0-82066000-1389908750_thumb.jpgpost-132008-0-72274000-1389908789_thumb.jpgpost-132008-0-63131100-1389908832_thumb.jpgpost-132008-0-75630800-1389908996_thumb.jpgpost-132008-0-56459800-1389908998_thumb.jpgpost-132008-0-58736900-1389909019_thumb.jpg
https://www.sau.com.au/forums/topic/437709-hi-hp-guys-i-need-some-help/
Beautiful car and great setup!
That is one majorly busted engine! I'm not sure you could blame the enlarged bolt holes or not. The crack runs through one of the holes but whether it originated from the hole or just ran through the path of least resistance which is the hole. Very hard to say. The vast majority of RB's floating around are far less than 1200HP so there may not be a lot of relevant experience on whether they crack at that point regularly. I've only seem RB's crack in the middle of the block and underneath at the sump mounting face. Yours is certainly an impressive effort (but obviously not appreciated!).
Good luck with it. Some of the sand racer Patrol guys over there might be able to shed some light on it as they're running similar power to yours.
Hi ZEEKH2B,
I can't speak form experience, but is it possible to drill and tap the head studs further down into the block?
This would spread the load across more block area (with more material above the intersection of stud to block) and possibly reduce the flex in the block.
You would need to find/make longer studs, but since the block is the weakest point at the moment, not the studs, this may be worth investigating.
The guys at RIPS in New Zealand play with some big HP RB's, they may have come across this issue previously.
http://www.ripsracing.com/
Hope it helped.
Mark :)
Heya PN-MAD,
I was more thinking that if the same thread was moved further down in the block, it'd have more material above it to reduce flex.
If the thread was longer it'd spread the load over more area. So if the thread pulled through, I'd go for a longer thread for sure. What do you think? Just throwing around some ideas :)
I guess it's much of a muchness...
Furthermore, if the thread was moved/extended lower into the block it'd also have less stress on the thin cylinder/stud wall from combustion.
Mark :)
Heya PN-MAD,
Mark :)
I'm far from experienced, but I guess at a certain level it just becomes R&D. Unless you can get some info out of the big builders (RIPS Maatouks etc).
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
