All items from my personal GTR 32. Located in Melbourne.
Air conditioner cooling unit - $220
Heating unit assembly - $240
Complete blower motor and fan assembly. Working well. - $150
Transfer case originally from R33 GTR - $220
Rear seat (back and bottom). Excellent condition - $120
Cusco strut tower bars suit R32 Front and rear. Avg condition. Scratches and paint chips - $180 pair
Weather strip retainers (L&R). Poor condition rubber strips, both suit restoring. Metal guides are excellent condition - $40 pair
Rear wiper motor - $90
GTR floor mats. Complete set. Avg condition, usual wear, no holes - $140 set
Interior carpet. Good condition. No stains, no burns. 2 small cuts for harness bolts - $120
Air con compressor, bracket, gas cylinder, and hose - $130
CUSCO springs (from Zero 2E coliovers) Cusco ID65 200 series. Spring rate: 11kg, Inner spring diameter: 65mm, Length: 200mm, Stroke: 100mm. Travelled 2000kms - $120 pair
GTR 32 front grill (silver) Good condition. Centre plastic clip missing - $110
Interior rear side trims (L&R) Excellent condition. All clips in tact, no tears in vinyl - $80 pair
Factory gauges for boost, water temp, battery. Fits into single din slot. Comes with loom plug - $110
Rear seat belts. Excellent condition. Barely used. Belts retracted into spool. Comes with fitting bolts - $100 pair
Climate control head unit. Good condition. All buttons work. Comes with loom plug - $90
Top cowl cover Fits under front wipers. Excellent condition, no damage - $40
Complete heater / AC ducting. Full kit includes behind dash and under carpet ducts - $30 set
Rear window lower outer moulding. No damage - $35
Rubber weather shields (L&R). Heavily worn but still working - $30 pair
Front door outside moulds (L&R). Poor condition. Suit painting - $40 pair
A-pillar trims (L&R) 3 small holes in drivers side for pod gauge fitting - $40 pair
Rear parcel shelf (original). Good condition - $40
Original Nissan brake lines and used Bendix pads - $40
Nissan standard CAM gears - $40
Oil catch can. Never used. Looks about the size of 500ml - $20
Rear seat firewall plate. Avg condition. Some scratches - $35
RB26DETT oil air breathers and joins - $20
Antenna booster - 12V amplified New. Boosts weak FM radio signal (10dB gain). Problem particular to R32's where the antenna is built into the windscreen - $20
Under bonnet trim Avg condition. No damage, just needs a clean - $20
Sun visors (L&R) Avg condition. Need a clean - $25 pair
Boot trim, carpet, and board Good condition. Left side trim torn slightly. Holes cut in side trims for struct tower bar. Selling as set - $25 set
Rear window wiper -$20
Nissan spare jack (original) - $15
Child anchor points and brackets Fitted onto rear parcel shelf during compliance process - $15
Interior roof lining. Excellent condition. No damage - $20
Pics available for all items..
https://www.sau.com.au/forums/topic/437715-random-parts-r32-gtr/
  • 2 months later...
Hi just wondering if you are able to ship the rear windscreen moulding?
If you are referring to the rubber moulds, these are heavily worn. If you are talking about the hard plastic moulds, then yes I can post within Aust.
Allow $15 for postage
  • 3 months later...
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
