See this turbo housing ? This is the exhaust side
See the little circular flap and actuator arm - this and example of an internal or integral wastegate - In other words, it's integrated into the exhaust housing
Here's another pic of a housing with an internal gate
Internally gated turbo's require an actuator to open the gate:
This next pic is an example of a turbo with an external gate
The wastegate is mounted on the exhaust manifold.
Here's another
The actuator is built into the external gate.
A wastegated turbocharger includes an integral device to limit turbo boost. This consists of a pneumatic actuator connected to a valve assembly mounted inside the turbine housing. By connecting the pneumatic actuator to boost pressure, the turbo is able to limit its maximum boost output. The net result is increased durability, quicker time to boost, and adjustability of boost.clear.gif
What's the difference between internal and external wastegates?
Internal wastegates are comprised of a flapper door which is built in the turbine housing, usually operated pneumatically by a mechanical actuator. These flapper doors are limited in size, but work well in certain applications. Usually found in smaller turbos, internal wastegates are relatively inexpensive, simple in design, and very durable. Larger turbo can be fitted with internal wastegates, but boost control can be tricky. If you are looking to run high boost (20+ psi) all the time, then an internal gate may be fine. If you are looking to run lower boost levels, you will need an external wastegate.
External wastegates are generally mounted to the exhaust manifold or to the O2 housing, and are self contained units. External wastegates have the ability to bypass large amounts of air, and can provide steady boost control at any pressure level. A common myth is that in order to run higher boost pressures, you need a larger wastegate. This is incorrect. Larger wastegates are necessary to run low boost levels on large turbos.
so would it hurt to put a large waste gate on a small turbo?
One thing is that large high mount external gate turbos are hardly stealth installs.
Pop the bonnet and everyone, esp. cops will know the car is 'off its teats'.
Also I note that many people love the high mounts and big gates so that they can run a screamer pipe that is also illegal.
But to make serious hp - say around 300rwkW, you pretty much need an external gate system.
T.
Ditto Abo.
Thanks B-Man :D
Is their a recommended brand/model or are all the Japanese brands similar in quality/performance ?
Ben, I have never heard a bad report on the performance of an external gate - they are pretty simple devices. (yet expensive)
Known Brands are:
Trust / GReddy
TIAL
TurboSmart
HKS
    • Did you find that your voltage of the battery wasn't where it's normally supposed to be? for example on my r34, it's at 14.5v when running after a few seconds, but I noticed when I had a rough start and it initially wasn't idling correctly, the voltage on my triple gauge cluster was showing lower than usual. Seems like the alternator is starting to crap itself
    • And, given that you're in NC, go buy an LS7 or something equally sweet and piss that crappy old RB off. Or call up Wesley Kagan and get his help putting a Merc V12 into it.
    • Do a compression test, and a bore scope on the cylinder that lost parts of the plug. Chances are, that cylinder isn't so happy anymore...
    • Update from today; Hard work was completed today behind a computer... Ha ha Hardlines for new fuel lines ordered, and fittings for it to connect up too. Banjo fittings for owner steer ordered too, will be AN fittings. Ordered all the weld on fittings I need to build the PS reservoir too. Only things I'll need left for power steer is a couple of off the shelf fittings for the pump, and to build 3 lines.
