I've decided to part out my sileighty due to no time to spend on it any more. All prices are slightly negotiable. SMS me on 0416953142 for pictures. All items are currently in Goulburn but will be available in Sydney soon.
Recaro SR4 seats
Black mint condition, no rails. Minor cigarette burn on drivers seat
$1,100
evo8 brake kit for S chassis
complete bolt on kit made by MSA, uses Evo 8 brembo calipers, and brand new 356mm slotted rotor and new intima brake pads
$1,000
RB26 long nose crank
Complete motor, minus hotside, ecu, injectors and coilpacks
$2,500
Precision 6262 turbo
All parts brand new, powertune RB26 manifold, 44mm precision gate.
$3,000
R34 GTT box
Pull type, will through in R33 GTST bellhousing (push type) good condition, no crunches etc
$1,200
NPC clutch and flywheel
Brand new
$1,100
Haltech PS1000 type x loom
Used for 100km
$1,500
VSKF
Brand new in box, discontinued
18x9.5 -10 18x10.5 -12
R disk O disk
Burning black polished lip
$3000
carbon origin rear seats for 180SX/S13
used, has minor scratches but can be buffed out
$500
RB20 engine
Complete loom, turbo, ecu. Intake manifold off due to blown gasket.
$500
2 way LSD
Unknown brand, to suit R200 diff.
$500
Racepak IQ3
Basically brand new
$700
Regamasters 17/18 stagger
17x9 +18 and 18x9 +18
215/40R17 and 215/40R18 50% tread
$2,000
hardrace R32 camber arms
brand spankers
$200
nismo timing belt kit RB
brand new
$400
ARP head studs RB26
Brand new
$250
modified RB26 rwd sump
comes with tomei baffle plates
$300
3.5 inch exhaust S13/180
Mild steel, tucked up for max ground clearance. Twin tips
$350
tomei timing gears RB26
brand new
$250
RB20 50mm alloy radiator
Brand new
$100
S13/180sx racing logic coilovers 11/7 springs
Pillowball tops
Less than 2000km use
$800
R32 GTST front cross member
$100
  • 1 month later...
  • 1 year later...
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
    • It's all the sound deadening, and extra shit piled into them, plus all the extra (even though it's thinner) material for crumple zones. I can't fathom in modern cars why they need canbus to the headlights, and why the headlights must be vin coded on some cars to the ECU, BCM, and security module! Especially when they claim it's for security, yet, the canbus at the headlights let's thieves steal the car in minutes, so even more cars are being stolen! The Mercedes Sprinter 907 vans. They're a huge van, but a "basic" van. Yet they have that many canbus networks, plus two Lin networks, AND an Ethernet network. Logging a single network alone of 8 byte data frames, and they will generate a 20mb log file in 5 minutes. That's one network, and I can't remember the exact amount, but there's over 10 full CAN2.0B networks in them. I'm not a fan of modern cars, oddly, more and more I hate DBW, and all the bullshittery the cars try and interfere with. But all that bullshittery adds weight, plus crazy regulations on crumple zones, plus, ever picked a modern seat up, half of them have like 4 electric motors in them and will weigh 30+kg each. Then all the motors for things like adjustable steering columns blah blah blah. And did I mention the sound deadening so you can even hear an ambulance right behind you even if you 7.2surround sound is off?
    • Ah ok, yeah it should be flat, I believe the r34 battery tray has these 3 bumps in them they makes it line up and everything is flat, don't see how it would tilt if everything is secured.
