is there a ftp site were we can download the 150meg file? Sending it through email will be difficult....
I'll download it and put it up on the ftp.
Hopefully this time it'll work...my ftp that is.
I'll let you all know when it's going.
The 32 manuals (both gtr and gtst) should be right to download now if you want them though.
ftp://[email protected]:77
Just click on this and internet explorer will goto the site. Drag and drop should work.
  • Replies 103
  • 4 months later...
