Hello fellow GTR enthusiasts.
First id like to say sorry for any offence but this is strictly a GTR get together.
Anyways as it is a start of a new year and the forums are dead I thought id organize a gathering of the TITANS as the tittle states.
So any of you with any model GTR are welcome to meet up for a chit chat, swap stories, share info or even sell stuff.
Thought we could get together and have a lunch or just have a few drinks and those who are keen a light journey into the hills, either for lunch or to sight see.......
Not sure if it will be night time or afternoon or morning yet but am thinking of February the 15th 2014.
I have organized many cruises in the past but thought something like this might be better and give other GTR owners a chance to meet and greet. So if we see each other on the street we can put a name/face to the car.
Im open for suggestions on anything but obviously I would like to keep the principal the same.
Thought the numbers would be not too large if it was just GTRs, and didn't want anything unmanageable.
thoughts, interests, opinions are welcome.
Anyone that has a problem with it need not post, simply move on to the next thread, thanks
Mike
Ok peoples.
The date is set for Sunday the 16th of February 2015. Sorry if this does not suit everyone but it is very hard to accommodate for all.
The meet and greet is going to be at 401 Greenhill road, Burnside Community Centre at 10:00am. Just before the Burnside Village on Portrush road.
All other Information about the day will be given at the meet point.
Hope to see all GTR owners there.
Will be a pretty casual day and for us all to chat and mingle, swap/sell stuff and organize future events.
Cheers
Mike
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
