Hi all,
Due to a setup change on my R33 GTR, I have for sale my excellent condition set of Genuine Tein Control Master Type Flex Coilovers, complete with the Tein EDFC (Electronic Damping Force Controller)
These coilovers are top shelf quality and manufactured in Japan, not China, and are suitable for BCNR33 and will also fit BNR34
All 4 are in outstanding condition, and have seen very little use overall - My car came with this setup fitted and in as new condition, and has since covered around 3,000 km's only.
Spring rates are 8kg (F) 7kg ® from memory, and provide a great range of adjustment to make them firm yet comfortable for everyday driving, while also being excellent on the track.
The EDFC gives you the ability to quickly and easily adjust the damper settings on the fly, from inside the cabin.
Technical Information from Tein:
TEIN has used its years of experience in various motor sports to produce a kit that provides the ultimate balance between comfort and performance. Developed for drivers seeking an aggressive coilover that can be used daily, and provide all the adjustments needed for circuit use. The FLEX damper Kit features the latest technology for all drivers who are seeking performance, and adjustability, while not giving up all ride comfort. We have incorporated separate spring perch height, and shell case length adjustment, which allows the suspension to retain more stroke and allows for more suspension tuning. The FLEX damper kit includes pillow ball upper mounts, which increase steering response; 16 levels of damping force adjustment, and is compatible with the EDFC (Electronic Damping Force Controller) for added convenience and adjustability.
Standard Features:
• Steel Construction
• Twin Tube internal construction
• Ride Height adjustable via threaded body and spring seats
• 16 way adjustable dampers, compression and rebound combined
• Pillow ball upper mounts for increased steering feel
• Upper camber adjustment on front for strut type vehicles
• Larger piston diameter for strut type front and rear (22mm)
• EDFC (Electronic Damping Force Controller) compatible
• Powder coated brackets with Teflon coated shock body for heavy duty rust prevention
Per the Tein USA Official website, the Control Master Type Flex base kit will set you back around $3000USD, and that does not the EDFC, which will add another $400 or so.
I am asking $980.00 firm for the whole kit - Note this is DIRT cheap, so please don't haggle or try low balling.
Pickup available on the North Shore in Sydney, or alternatively you are welcome to organise your own courier to pick up.
First in, best dressed!
Cheers :)
I have had these coilovers in my car for 6 years and feel exactly the same today as they did back then.
Quality product!
Not at this stage sorry mate, I would prefer to sell the EDFC and suspension as a package.
Price drop to $900.00 FIRM!
As above, and per the photos, they are in excellent condition and were only removed due to a complete change in my setup, so there is no need to rebuild.
This is a high end Japanese coil over package that I'm selling at a dirt cheap price purely to move them, it's a damn good suspension setup for minimal money, so my loss will be someone else's gain here.
Cheers!
    • You'll need to put your acquisitions hat on Mark, especially on your last day. Acquisitions really is a great talent of defence personnel
    • And the rules change with time ...but speaking to the premise you raise here, some of us old farts will remember seeing every police motorbike with a rubber rear mudflap extension, fitted to the end of the rear mudguard. This was due to an ADR that required the rear mudguard to extend lower than the rear axle (iirc 15 degrees lower as measured at the axle center line)...it was changed in '89 updates, but basically before that date, any road going motorbike was technically 'illegal' (unroadworthy) ...the whole area is a real prickly pear... 😃
    • What wires were for the revers light
    • One thing that I will miss when I retire from full time is my access to the laboratory ovens at work we use for soils testing  Jackie has forbade me from using the oven at home for curing paint...LOL The paint on the NC's OEM "strut" brace thingo was a little off, so some prep and some gloss black "Raptor" wheel paint I had left over made them all pretty again, the parts will sit in there overnight at 30°c and be ready to reinstall  tomorrow
