Hello SAU
Need a bit of guidance as to what needs to be done. Haven't checked any of this stuff before so it's a learning experience.
Long story short - Drifting 3rd gear full boost and I saw oil pressure drop, turned off car immediately and rolled back into pits. Did a quick start, Oil pressure was back up put it on the trailer and that was it. Pulled motor today to check the damage.
These are pictures of the bearing cap and bottom half of bearing. In my opinion it's the worse of the lot. Do I replace it or it it ok to go back in?
Bearing Cap
Bearing
What do you guys think?
Also if it's bad, Can I just pull the crank and pistons out, replace/machine crank if need be and new bearings. Do I need to do anything with the pistons and rods? Like adjust or replace rings? Get anything checked? Or can I just bolt the rods back to the crank and put it back in no worries?
Thanks all.
https://www.sau.com.au/forums/topic/437771-spun-bearings/
How are the crank journals, scored?
Was a bearing spun?
If so dont muck around, in fact id look at getting some beefier rods in there to avoid this happening again.
Hows the oil pump, is it cracked?
What happened, were you holding the revs up high for a while, while redlining it? If so could be oil surge that built up in the head and dried out your sump that caused this.....good oil drain back to the sump is a known RB issue.
https://www.sau.com.au/forums/topic/437771-spun-bearings/#findComment-7173538
Was a bearing spun?
Crank looked alright to me and bearings had not moved. There was no rod knock that i could hear after it happened. I just assumed the worst.
Have not looked at the oil pump yet. Was likely going to opt for a new one anyway.
Was holding about 5500-6000 rpm i dont like getting near limiter if possible.
Motor has done 2 sprint days and about 11 drift days now and this is my first engine issue.
https://www.sau.com.au/forums/topic/437771-spun-bearings/#findComment-7173564
Does it make any noise when running, like a nock nock nock sound?
To me It looks fine in those pics.
My old RB20 did this, drop oil pressure to zero under sudden heavy breaking, then come back up straight away. Although it eventually developed a nock.
https://www.sau.com.au/forums/topic/437771-spun-bearings/#findComment-7173566
Yeah thats why my questions were worded as they were.
It does not look like a spun bearing, cap does not look like its cooked, id be looking elsewhere for the oil pressure drop.
I would however inspect all bearings for metal to metal contact before reassembly in case one or more is damaged due to the momentary pressure drop.
One thing about track days and drift sessions is the high g loadings can move the oil away from the pickup, add to that higher RPMS which pools the oil in the head and its a recipy for oil starvation and spun bearings.
If all checks out OK drop a oil restrictor in under the head, and a larger oil sump with trap doors and longer pickup to make sure you dont starve it of oil at minimum.
https://www.sau.com.au/forums/topic/437771-spun-bearings/#findComment-7173643
There was no knocking sound that I could hear afterwards. Didn't want to run the engine for more than a couple seconds incase somthing was up.
Will check everything out today and see if there is any damage.
Ordered an oil restrictor and some fittings for a head drain last night so it will be done before motor goes back in. Going to check out sump options now.
Cheers
https://www.sau.com.au/forums/topic/437771-spun-bearings/#findComment-7173679
Cheers
Forget the "head drain" - read the last 10 or so pages (or the whole thread if you have time to kill) of the oil control thread: http://www.skylinesaustralia.com/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/?&hl=sk+oil+control
https://www.sau.com.au/forums/topic/437771-spun-bearings/#findComment-7174447
I don't see a problem with the bearings or the cap. Looks fine with no actual significant wear.
I would check the pump for issues but if its fine I would put the car back together with a good aftermarket oil pressure gauge (assuming you were basing the reading off the OEM gauge).
https://www.sau.com.au/forums/topic/437771-spun-bearings/#findComment-7175698
Just replace it. Bearings are worth stuff all and well worth being changed given the motor is out.
With regard to the rest of the motor, if you can afford it rebuild it if you plan to continue drifting it as its a pretty destructive sport. The engine will need to be rebuilt sooner or later so why not do it now ;)
https://www.sau.com.au/forums/topic/437771-spun-bearings/#findComment-7178670
how do you know the oil pressure was down? what if the gauge was having a hissy fit ?
Honestly I don't, I bought a new gauge anyway and will most likely run them both.
Had a good read of all of it.
I've already got the fittings to do it, even if it just acts as a sump breather then it's better than nothing.
Thanks man, new bearings are sitting here ready to go on tomorrow anyway. Pump is off tomorrow too. Would like to replace it but will see what it's like.
Bearings are getting done tomorrow.
I'd love to do a rebuild but it's a large expense I can't afford at the moment. I will of course one day, just hoping to get what I can out of it now before I take that path.
Destructive is an understatement.
Thanks For the input!
https://www.sau.com.au/forums/topic/437771-spun-bearings/#findComment-7179420
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
    • I'm pretty sure if it's considered a gasoline powered vehicle you have to do certification against a fixed, very expensive certification fuel.  If you add two precats and then replace the main cat with two cats back to back you can get an RB26 to do 0.24 g/mi HC, 1.6 g/mi CO, and 0.3 g/mi NOx on the FTP-75 drive cycle. Found this out courtesy of California's laws at great expense. Divide by 1.61 to get g/km. So even with extra cats + precats you're blowing past the NOx limit by probably 2.3x. Probably the only way to get an RB25 or RB26 to meet euro 4 purely from an emissions per km standpoint and not durability/OBD2 requirements is retrofit at least intake side VVT, clearance the pistons to allow the full 50 degrees of advance so part throttle EGR can be maximized, and change the wastegate control from conventional 7 psi spring for example to one that is always fully open if the wastegate line is at 1 atm or higher and only close it in response to vacuum. See BMW's N54 engine as a reference for how this works. You would need to find space for a vacuum tank to function as an accumulator in this system. That way you can avoid any heat loss to the turbine as much as possible during cold start to heat the catalyst faster. Then find some way to eliminate as much as possible cold start enrichment to light off the catalyst rapidly. Maybe secondary air injection if there's no way to avoid cold start enrichment. Close coupled catalysts in the downpipe are probably necessary. I would also probably swap to EV14s, pick something with the correct spray targeting + dual cone pattern for the intake manifold you're using. EV1 style injectors to pass anything resembling modern emissions requires a very annoying air assisted injector system to break up the droplets at part throttle/idle which still doesn't work that great compared to just having smaller droplets from the injector to begin with. Realistically, you're probably going to be financially ahead if you just pay the fines instead. Or don't drive it into the city center. There's a reason why Nissan never bothered to even attempt certifying an RB for CA/US emissions. The VG30 needed external EGR on top of NVCS to pass in the 90s. Doing all of this work is also distinctly expensive and you're going to struggle to find anyone who is remotely interested in helping.
    • I remember those, people use to steal them to make bongs.....
    • IIRC, it only cost me a couple of hundred dollars to get an Liverpool Exhaust to fabricate a custom stainless resonator for me to fit in the available realestate that I had under the car I actually watched as they did it, took about 1 hour to cut up the material, tig weld the body of it, and then add it to the exhaust  4"in and out, with a packed 5" body, that was about 12" long In the end, it is some blindly simple sheet metal work for an exhaust shop, and some welding
