Hi All,
I was hoping to seek some assistance in getting an R35 GT-R as well as a R34 GT-R for my upcoming wedding in October.
It will be in the afternoon of the 11th October 14 down at Currumbin Valley. Times are yet to be finalised at the moment, however we are looking at early afternoon. Payment will be provided if anyone is able to assist of course.
Would love it if anyone could help make this special day even better!!
Larissa.
https://www.sau.com.au/forums/topic/437793-wedding-assistanceplease/
I would love to have 2 35s and a 34 GT-R. As for colours, I'm not going to be picky. I doubt I will have a vast array of cars to choose from, so I think I'd be happy with almost anything that comes my way!
I was really hoping to get the second 35 for the boys - Getting married to Gumflapper, who has been on this forum for quite some time, so I know he would like to get a nice ride as well :)
defari - Appreciate the offer, but not what I'm looking for :)
Captain Natro - have you any photos?
StretchGSK - Good point...
The cars will essentially be to transport the bridal party and for some photos after the ceremony, if the owners don't mind. The venue is a bit out in the sticks with some nice winding roads - it's on Baines Road, Currumbin Valley.
It depends what cars we are able to get as to the configuration. I was wanting to have the R35 for me, and if we could get a second, I was hoping to put the boys (x3) in one as well, however it would have to get to the venue earlier. If that all works out, and I'm able to get a R34, I'd put the bridesmaids (x2) in that, or a R33.
As I mentioned above, we will certainly provide payment for your generosity. What's the going rate these days? I've got no clue...
Well I really should have congratulated you first on getting engaged...
I am moving to QLD in the next month or 6 weeks and will be bringing my R34 GTR with me and would be more than happy to help you out on your special day.
As you say it is still some time away, but put me on your list and we can firm up the details once I get to QLD.
    • It can't be some stupidly proprietary video signal coming out of it that only Nissan's can understand. Surely you can just find some generic camera to stuff in there and use hot melt glue/blu-tac/gaffer tape to hold it in place if need be?
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
