I've recently bought a used Pfc for my r33 Gtst, also bought the map sensor, solenoid and the 3 pin wiring loom separately.
Everything is hooked up and I'm getting unlimited boost
Things I have checked:
Soldered red wire of the solenoid on to the white wire on the plug, and black to black- this should be right?
Blew through the com port on solenoid, air goes right through to the NO port when unplugged
When plugged and car idling- still blows through though with resistance
Pull out the multimeter and checked the plug, ecu side female- getting 3v on idle and constant 13v when the engine revs up a little
This explains why I'm getting unlimited boost because solenoid would've been shut the whole time
I assume that the boost controller is switched off on the PFC or otherwise I wouldn't be able to start the car according to Paulr33's guide
The PFC is the first gen, didn't come with a hand controller so I'm flying blind with the settings
Ecu wiring doesn't seem to have been touched before, other than the usual alarm immobilizer, though it was running a nissan remanufactured ECU
Solenoid is unplugged for now, so I'm just running standard boost
So question is- have I wired the solenoid wrong way round? Or is the Pfc faulty? I'm a bit hesitant in cutting the wires and resoldering it again because there's not a lot of length left. Also searched and remember someone saying that if it's wired the wrong way it just simply won't work- so you get stock boost
Any help is appreciated
You have to turn it on or ot doesnt work. I had one and was driving with just a line to the wastegate once with the solenoid off. Then plugged it all back in and forgot to turn it on and ran 25psi of boost or something like that
You have to use the hand controller or computer software to turn it on. The hand controller makes it much easier to alter the boost settings to set it up to because it takes a bit of playing around to get it right
It should run on wastegate duty without the actuator being pulsed.
Boost control must be setup correctly.
are you running a internal or external gate?
which ports on the external gate are plumbed to where? or how have you got the actuator connected? and where are the connected to on which ports on the solenoid?
too many variables.. take it to someone who knows what they are doing to install it for you... or this might help. its how it should be setup for a external gate single turbo setup.
INTERNAL SETUP is very different again!
  • Like 1
89cal's experience sounds like what I'm getting, just thought that with the boost control turned off it should run standard boost off the gate, I'll wait for the hand controller to arrive first
Btw it's standard turbo, so installation is pretty straight forward with no port to intercooler piping and com port to actuator from memory, installed an avcr on old car so not exactly rocket science
Just as a FYI the voltage should fluctuate, even at idle.
And also I suggest you trim off timing on the standard base map before you decide to ramp the boost up as the stock map is super crazy aggressive, however it's pretty rich, better yet bring it to a tuner.
Yup the voltage fluctuates between 2-4v on idle
Only hits steady 13.x when the throttle is open
So if I had the stock solenoid on, it would run the high boost (7psi) mode full time, which makes sense
Just going to run straight off the actuator for now, will test the boost controller again when the HC arrives, and just baby it til I get it tuned
  • 2 months later...
so here's the update- still trying to get this to work
went away for holidays, came back and battery died
replaced battery and installed the hand controller, no more unlimited boost with boost controller function off, but with boost controller on i'm also getting standard boost (~7psi stock turbo)
realised map sensor wasn't the right one, so changed that now it reads boost perfectly fine, but still no boost control. doesn't matter how much boost and duty cycle
so brought out the multimeter, here's the result
unplugged solenoid, tested voltage, getting fluctuating voltage with B/C off, same as before
plugged it back and cut the wire between the plug and solenoid- still getting the fluctuating voltage, ie power FC is sending through voltage and the plug contact is fine
tested solenoid by directly hooking it up to battery- ticks so solenoid works
soldered the solenoid back on, tested voltage on the exposed wire before i heat shrink it- 0v with B/C on or off!
i'm pretty confused with what's happening here, everything seems to work fine but just won't work when i put them together
I've also tried adjusting the duty cycle from 50~70 on boost profile 1, 10psi/ 0.7kg/cm2, still no good
Edited by chiksluvit
Do you think its going to get a signal when it has negative pressure? The solenoid default is normally closed, so no voltage when normally closed. With the car in vacuum its not going to want to be opening the solenoid.
Im not suprised there is no voltage there
Have you tried driving the car and seeing if it works? Remember if you have it set to 7 psi then it will cut out if it goes to around 9-10 psi so you dont need to worry too much about overboosting
Have test driven it a lot of times and not getting any boost control, no matter how I set it, still getting standard 7psi, PFC set on 10psi
It gets voltage with BC off when engines idling, solenoid unplugged.
Plug it in and no voltage again
You're right there's no voltage when BC is turned on
I thought you're meant to get roughly 3v fluctuation during idle
Have you measured resistance through the solenoid coil? Should be resonably low.
I was pretty sure the solenoid was normally closed so if you are getting less then desired boost then it seems a bit weird. If the solenoid was wrecked it would boost till things exploded.
What are your boost settings? Do you hit boost cut at all when you put your foot down?
no I haven't tested the resistance on the solenoid, then again i'm not really good with multimeters so I'm not sure how to check that or even what the numbers mean- anyway so here's what i've done
Electrical tests
solenoid unplugged BC on: 0.3v @ idle, fluctuates a bit when revved in neutral, can go all the way to 3v
solenoid unplugged BC off: 0.3 at idle and full 13v when revved slightly
solenoid plugged: 0v BC on or off, rev or idle, the +ve side is constantly getting the 13v, so just the ground side not grounding when its supposed to.
like as if the PFC knows i've got the solenoid connected and decides to not work caus it didn't like the solenoid
Plumbing
Its stock internal gated turbo, so plumbing's different to the diagram. I'm very sure the solenoid is plumbed right, plumbed the AVCR on my old car the same way according to apexi's instruction and it worked, NO to intercooler piping and COM to actuator, NC left out; so according to guilt-toy's diagram it would be port 2 to actuator, port 3 to intercooler piping
Driving and PFC setting
redlined the car a few times, no boost cut, max boost is 0.55, thats 7~8 psi, won't go over 0.6kgcm2
tried running the boost signal directly from intercooler pipe to the actuator, same result- this suggests the solenoid was not working at all
it's currently set at 0.7kgcm2, duty cycle 50. Have tried both 0.7kgcm2 and 1kgcm2 with duty cycle ranging from 40~90 in both boost settings, yet no difference
everything else on the PFC is fine, i can change the AFM setting it'll run like crap, fuel and ign map's been tuned and it drives nicer than before, change the idle rpm and engine responds, no other problems other than the annoying fact that BC won't work
Other things I've tried
funny how it all started with unlimited boost before i got my FC commander, turned BC on after I got the FC commander and I then get standard boost no matter how I set it, turn it off and no more unlimited boost
tried pulling the FC commander out too and yet still standard boost, BC on or off, made no difference
Solenoid
Solenoid is normally open, if you plumb it to NO port (port 3) for internal gated turbos
It would be normally closed if you plumb it to NC port (port 1), but thats for external gated setups
Have also bought a MAC solenoid to try out, and that won't work either. Tested both of the solenoids and they would click as soon as i connect them directly to the dead battery i have sitting in my garage, still getting around 10v on that
not sure if there's anything special about the apexi solenoid? has anyone had any success running a non genuine solenoid like MAC valve on the PFC? it seems like the RX7 guys like to use them with PFC as they're cheap and does the job
it was easy on my friend's r34 GTR, plugged it in, turned BC on, and hear solenoid ticking away when the +ve pressure starts to build
my car- dead as a starfish
i'm almost at the point of giving up and just going to get a turbotech
Plumbing
[Solenoid
I have no experience with PFC but Mac Solenoids can replace the solenoid on most boost controllers and in fact many boost controllers just use rebadged Mac valves.
I suspect yours is plumbed wrongly. If it were a Mac valve I think you should supply boost (from your intercooler pipe) to Port 1 and run port 2 to the actuator. Can you try this? (no doubt you would have to make adjustments to the PFC). [With a Link it makes no difference if the valve is NO or NC as you just adjust the duty cycle accordingly]
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
