Looking to sell my 1994 R33 Type M Skyline.
Bought the car just over 12 months ago completley stock bar a set of 17's and blown coilovers. I've added everything in the last 12 months, so all parts have very minimal use on them. Majority have less then 5000kms. I have almost all receipts for what ive bought and what work ive had done, and it's many thousands of dollars, more than the asking price.
I'll get the bad points out of the way first...
Both front fenders are munted. Previous owner rolled them REALLY badly, and the D/S has a couple of dents. Has a couple of carpark scratches and dents. Roof, bonnet and top of rear bumper have clear coat fade, but polish up ok. However does require respray to fix.
It's all cosmetic issues, which was all I had left to finish, once the mechanicals/driveline had been sorted. Get a pair of 25mm FRP front fenders and have the car blown over in the factory colour and it's done. Was quoted between $1000 - $1200 for a decent closed door spray in OEM black, you could spend more for a REALLY good job, or if you know someone who can do it you're golden
Now the good stuff...
Car is religiously maintained, using only the best gear (Nulon oil, redline gearbox and diff oil, ryco filters, Caltex 98 octane fuel) and also upgraded with the best parts money can buy. All work not done by myself has been performed by Shaun @ Boostworx, and he can also be contacted in regards to the car. Also in the last 12 months ive replaced timing belt, cam seals, water pump, tie rod ends, lower control arm and knuckle bushes, all the belts, and had air con fully serviced and regassed. Car also has a Viper 2 way paging remote alarm with remote start.
It's a perfect streeter, absolute weapon to drive, hit 3500 rpm and its all over the street, but super easy to commute in day to day traffic., it's just become impractical for me to keep, and have other projects on the go that I would rather finish.
Body
Type M Front bar/sideskirts/pods/wing, 8000K HID kit
Interior
Bride Digo-R seats in black/gradation on bride rails (Both Genuine with receipts)
Nardi Classic Steering wheel/Sparco Detachable hub kit/Yashio Factory shift knob
HKS Boost/oil temp/oil pressure gauges in Border Gauge pod, Yashio Factory Water temp Meter (To be installed)
Kenwood Head Unit/Splits
Engine / driveline
Rebuilt RB25 motor - CP Pistons/ARP Hardware/Greddy Metal Head Gasket - Full reciepts for engine build - over $10K worth.
APEXi Pod Filter/ Z32 AFM/Stainless inlet pipe (Have another intake pipe with no connection for emissions)
Trust TD06SL2-20G 10cm turbo/GReddy High-mount Stainless Manifold/Tial MV44 Wastegate/Braided oil and water lines
Plazmaman FMIC And piping
1 piece dump/front/APEXi 3 inch exhaust (Not too loud, good on the street)
Nismo fuel pump/Nismo 550cc injectors
APEXi Power FC ECU tuned by Shaun @ Boostworx - 270rwkw @ 19psi with dyno sheets. More in it with a decat pipe and some cams.
Nismo GMAX twin plate clutch/Braided clutch line/urethane gearbox mount/Nismo pivot ball
Nismo 2 way LSD, alloy diff mounts
Alloy radiator/Silicone Hoses/Nismo Thermostat/N1 water pump
HKS oil cooler kit with filter relocation
Optima Dry Cell Battery
Wheel and Tyres
Enkei RPF1 wheels in silver, 18x9.5 -5 and 18x10.5 +10
215/40 and 235/40 Tyres
Suspension setup - FRONT
Cusco Comp S coilovers – 10kg
Cusco Adj. Upper arms
Cusco Adj. tension Rods
Nismo Tower Bar w/master cyl. brace
Suspesion setup - REAR
Cusco Comp S Coilovers – 8kg
Cusco Rear upper arms with eccentric lockouts
Cusco Cradle collars
HICAS lock bar
Im asking $13,000 negotiable upon inspection, car has current rego with just less than 3 months left.
May consider trade for HSV/V8 Commodore as a daily
Contact Ben on 0439 888 043, or [email protected]
Edited by R31 drift pig
What would be your best price you can do on it? Im interested and im from Melb so i wont need the reg or rwc and ill be paying cash, so if you can give me a really good price i will come and take it off your hands.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
