Hi Guys,
A few questions here regarding the headlights on the M35.
1. For a while now I've had problems with the headlights cutting out (many times every time I drive it). It used to be only the passenger side lamp and figured I could swap the ballasts over to see if that's the problem however now it's both so I guess that isn't an option any more. I am assuming it's the ballast anyway but any thoughts as to how I would tell given that both cut out (at separate intervals - not at the same time).
2. Any one know what ballasts we can use? Preferably cheap ones? Or official model numbers?
3. I personal find the lamps pretty dull (doesn't help that you can't adjust them any higher than about 2ft in front of the car), any suggestions for a brighter bulb?
4. My passenger side parker lamp is also out, does anyone know the model number or aftermarket options?
Sorry about all the questions but any help would be GREATLY appreciated!
Thanks all,
haha yeh tried that just doesn't get quite high enough imo. Might just be a preference thing or the whole unit is badly aligned. Or I was just recently in a late model RX-8 and got jealous of the perfect line those things throw across the horizon. Amazing!
You can get cheaper ballasts of eBay and xenon burners aswell both for pritty cheap I got some bulds there before had a problem with them cutting out but it generally the bulbs going not the ballasts. I got 10000k bulbs super bright great light dispersion aswell but don't last asking as OEM ones but are 1/10 the price $8 for two so I just bought 6 pairs one pair lasts about a year.
That's exactly what I wanted to hear. Thanks!
10000k are far too blue; even 6000k are getting too blue in my opinion.
You want 4200k for the best light dispersion. Coincidentally this is what they use from the factory.
if the switch inside is at the highest point they you will need to adjust them by screwing the plastic nut on the back of your lights( it is on the little motor attached to the rear of your headlights).
Do HID bulbs need replacing after a periosd of time? I saw on another unrelated forum a discussion about replacing HID bulbs after a few years as they begin to lose their brightness, does this sound right? Mine are fine (I think) but they are 10 years old and I will replace them if they are a consumable item. The discussion was around BMW HID bulbs in cars built around the same time as m35.
They will lose brightness over time, but seriously, how many hours a day do you use them on average? They might last years longer, and at the price of OEM burners I would keep the old ones a little longer.
Fair enough I think mine are ok but not as powerful as I'd hoped but as you say I don't use mine much. I'm in no hurry to replace them and thought I'd ask as I hadn't heard that the lose brightness over time previously. What are new bulbs worth anyway?
  • 3 weeks later...
New bulbs surely produce more light!
always running with lights on (law tells so even in shiny days)
3 month ago i replaced oem bulbs (i believe factory ones, never changed before) with Osram 66050 (d2r for OEM installation), 50USD/pair - difference is visible
6000k bulbs put out an icy white light with a hint of blue. Sunlight is typically around the 4500k (white spectra), hence why manufacturers use that figure. The higher you go in k number, light quality reduces. 8-10,000k is useless as its in the violet spectra.
Not sure why Nissan, in their wisdom went with a spread reflector instead of a projector type lense.
In saying that, I converted my R32 to HID with the projector type lense & the the light dispersion was crap, nowhere near as sharp as it was in my E30 BMW (I ran 6500k & halogen high beam on the highway was not needed!). So in saying that, the reflector setup inside the projector has alot to do with how well the transfer of light occurs.
From memory, in my C34 S2 they are D1R or D2R 6500k, bought off ebay (china) around 2yrs ago, & still going strong.
  • 2 years later...
Should have told richzx to replace them lol. Now i'm in charge of replacement so they lasted a further 2 years and 9 months.
Edited by stripey
update names
    • Given you already have the engine cross member to match and likely gearbox mount to. The SR20 has a head start on the RB in this case. They handle GREAT with an SR20, lots of fun.   One I did back in the day
    • have no doubt and wanted too trust me and may regret later not necessarily worried about weight (would be 8 kg ish total) it was more the $$ to do it properly is about $6 - $7K in hardwear need long 310mm stroke jacks etc - plus install and call me whatever im not doing it myself even if wanted too cant weld etc  - thats $10K installed vs fraction of that cost while Ive spent some money on this POS I actually really dont like doing so unless its got a large chance to make me go faster 😁 hey in still carting this things around on a 15 yr old rusted open trailer so I can spend on racing not buy a new trailer to look better the manual jacks Ive had done are heavy and take space but are transportable and usable anywhere - taking or organizing even compressed air let alone nitrogen which is more whats needed coming from Perth to Winton or Sydney or the like honestly just adds to my brain headaches/ hurts of organisation also ha 15 mins job will get down to 2 - 5 min job vs 1 min job for airjacks - all tradeoffs I spose
    • Purely out of curiosity, how do you know all this @dbm7? Do you work with automatic gearboxes professionally? This goes way way way beyond "I've had an automatic Skyline once and did some mucking around"
    • I'll just reiterate that it's best to do all the wiring diagnostics, before even thinking about buying replacement solenoids ~ that is, be absolutely sure the solenoid is bad.....ie; bad connector(s), rodents chewed through a wire, etc etc. If you don't so this, you can fork out all the money for solenoids, only to find something else is wrong (this'll make you cry if you pull the valvebody only to find a broken wire is at fault... ...some more glue on the solenoid packs -- this is the RE5R01A shift solenoid assembly.... ...these are all shift solenoids ~ ostensibly they're the same as the shift solenoids from the 4-speed auto.... ...this is the RE4R01A solenoid set... ...with these, you have 3 shift solenoids attached to the plate, and the separate solenoid is the EPC solenoid (line pressure control) -- with both designs, the TC lockup clutch solenoid (also PWM so they could slide the clutch shut), is located on the lower valvebody half.... ...(story time)...back in the 90's, it was a common fault that the EPC solenoid (or TC-lock solenoid) would fail, but Nissan only sold them as part of the assembly (think ~$350 at the time) ~ thing was, Isuzu also used these boxes in light commercials, and you could buy the PWM solenoid as a separate part, so it was possible to buy/use that solenoid (around $65), and make it fit (remove the circlip, fit to old plate and deal with wiring)...making it a more cost effective repair. I've not seen the RE5R01A shift solenoid assembly, but with the 4-speed RE4R01A it was possible to hack/fit a single shift solenoid onto an other working set, using a donor solenoid from another set with failed EPC....(by rights the whole set should be replaced), but it ends up being a question of how much life is left in the box itself ; sometimes it's a viable repair to fix one solenoid, just to get another 100k of road miles out of it before it needs first overhaul...other times the box is that old/worn, you're as well doing first overhaul and replacing the solenoids and starting fresh... What Nissan did here with the 5-speed, was relocate the EPC solenoid to the lower valvebody (next to the TC lockup solenoid), and stuck the direct-drive clutch solenoid (for the extra gear) where the EPC solenoid used to be on the 4-speed....I can only imagine they did this for serviceability ; the PWM solenoids are most likely to fail, and it's a doddle to drop the pan and change these out (as opposed to dropping the valvebody itself to get at a top mounted EPC)... ...also keep in mind, that some BMW 3/5 series & Mazda (and maybe some Ford/Mazda rebadges, not sure), also used the RE5R01A box under a different name/part number...not saying parts availability is any better, but sometimes it helps to know this when it comes to NOS floating about in the EU.... HTH
    • FWIW, air jacks are actually pretty light and simple to add, they are just 4 hydraulic cylinders (often at the main cage A and C pillar points) and an externally accessible airline  - they make quick work a breeze
