Hi guys,
I've got another fob for my 2006 V36 and I went (twice) to Ferntree Gully Nissan to program it.
They could not program it without GTR technician as there is some security key (I believe NATS requires special card to program these models), went one more time today but no luck (I am not sure they really tried as this attempt was much shorter than previous), so they recommended me to talk to Infiniti people.
I have spoken to Inifiniti service but they turned to be completely useless, although they're selling the same car (G37) and definitely have Consult III
Now I'm kind of stuck. Anyone knows a Nissan dealer in Melbourne who is capable of programming a fob?
https://www.sau.com.au/forums/topic/437969-programming-a-new-key-for-v36/
Just to let you know that I got mine done at City Nissan in November around $300 ish for the job, I had to purchase a blank key then they had the car for a day to get the special codes, then they sent the request over to Japan for the key code and then they contacted me two/four weeks later and dropped the car in for the day and all was great. I now have two fully working keys!
They have just moved to Abbotsford/Collingwood.
Call 03 8383 8800.
Hi guys,
Ferntree Gully Nissan did mine 3 years ago but they also supplied the key. How old is your V?
Wow it must have been the biggest hassle for them to do.
Sheesh, I must have been lucky.
on a side note I have found Paul at Osaka Imports helpful in sourcing 2006 V36 350GT SP parts.
I was told they need some key (20-digit or 12-digit, don't remember exactly) to program it using their tools
I thought once you've got consult 3 plus immo key card you don't need any codes as the tool goes into Chuck Norris mode and allow you to program any key.
Edited by Zveruga
haas just came across this looking at replacing the headlights of the V36 this weekend.
I have not tried this and I won't as I have working keys and don't want to stuff anything. (have I sold it enough yet too you!)
http://infinitihelp.com/diy/common/infiniti_reprogram_key_fob.php
this could just be for the infiniti however found we have a lot of the same setups.
Or just have a quick trip to SA and have a chat with Eye Candy!.
Without Smart Entry System
1. Close and lock all doors with the driver's side power lock/unlock switch.
2. Insert key into ignition and remove it from the ignition key cylinder at least six times within 10 seconds. Your Hazard Lamps will flash if you have performed this step successfully. NOTE: Withdraw key completely from ignition cylinder each time. If this procedure is performed too fast, system will not enter programming mode.
3. Insert key into the ignition cylinder and turn to the ACC position.
4. Within 5 seconds, push ANY button on the remote transmitter. Your Hazard Lamps should flash. NOTE: Do not press the button more than one time in the above step. If the button is pressed more than one time, the programming procedure will not be successful.
5. If there are any remaining transmitters (including the old ones), unlock then lock all doors using the driver's side power lock/unlock switch and within 5 seconds, push ANY button on the next remote. Your Hazard Lamps should flash. Repeat this step for each transmitter (including any existing transmitters).
6. Turn the key to the OFF position, remove keys from the ignition, unlock doors using the driver's side power lock/unlock switch and open the driver side door.
Thanks
Seems like the dealers aren't inclined to work on our imports as if they're looking to protect the local distribution channel. Stupid since they'll be getting paid for the service regardless. <br /><br />If I ever need to replace either of my two fobs, I think I'll have an easier time buying the security module for my Consult 3+ scan tool. Mongrels.
Again.. this is for the central locking remote, not the immobiliser..
programming the immoboliser requires a trip to a dealer, or some sort of consult device if you have your BCM PIN
Do you still need to know PIN if you have Consult III and the security card for immobilizer?
If it's that simple I'm thinking to buy Consult III and the card, make two fobs and sell both on eBay once done
Edited by Zveruga
not sure, but I think the dealer can program the immobiliser because they have the real Consult device and the NATS keycard and they don't need the PIN to do this.
I highly doubt you will be able to buy a NATS keycard as they are fairly tightly secured, and only available to dealers.
if you have the PIN, you can program NATS without the keycard.
Not exactly sure if this is the same for the 'intelligent keys/fob', but if Nissan go to that much trouble with keychip immobilisers then chances are the same security would be provided with the intelligent keys.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
