  • Replies 110
yeah i was a little dissapoined actually...
my excuse is all tyres, need some better and wider rubber, the crap standard tyres and wheels wouldnt hook up.
i ran a 13.5 @110mph
i plan to go out again with some decent tyres, anyone want to lend me some?
I just jumped into a random car and ran a 13.2... 2rismo did the same in some dudes silver line
Random car? If you believe the shove in the chest and earful I copped, he's your best mate/lover and not just a random car...
How good is it to race someone else's car...sweeet
AWESOME!!! I hear that :werd:
Adrian
