Guys I have tried searching but no real help.
I am trying to sort out a issue on my bro in laws r32, it won't rev past 3000rpm it coughs and splutters when it's warm. It has a z32, nistune, walbro pump, kkr 430 and a 14psi external gate and split fire coilpacka
There is no boost leak that I can find, spark plugs are gapped at .8 cleaned the afm, I don't have another afm so I can't try that. But it's really annoying me.
Also tends to stall when you come off the gas in neutral.
I am thinking of afm but don't have a z32 to try.
Any thoughts guys
https://www.sau.com.au/forums/topic/437980-r32-issues/
Idle control valve??? It idles at 2200rpm when it is plugged in and been told by previous owner it doesn't need to run it supposedly???? (Not sure if that's right though)
It's definately not ic piping or boost leak from silicone hoses that I can see at least.
I am starting to think tps or maybe idle control valve but that doesn't sort out the 3000rpm spluttering
I think he is gonna have to take it to a tuner.
https://www.sau.com.au/forums/topic/437980-r32-issues/#findComment-7177475
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
    • I could see someone trying this to save money on oil changes.
