LegionMe Posted January 22, 2014 Share Posted January 22, 2014 As the technology is getting smaller and more portable I was thinking of hooking up a ODB scanner to my 2006 V36 350GT SP skyline and outputting the values onto a iPad mini. I am trying to figure out what would be the best ODB Scanner to use? I have been told I need a wifi unit as the Bluetooth units won't talk to Apple as they speak different language. I had a odd warning that through net searching found out it was to do with the oil however would prefer to have a scan tool to help me with these warnings if they happen again. If anyone could point me in the right direction of an affordable unit that would be great. I have searched on here and basically I can see the one that you need a XP laptop for however I would like one to use with an iPad not laptop. thanks for any suggestions. I got a Vgate odb2 scanner that works a treat on the wife's Ford however hopeless with the skyline. Link to comment https://www.sau.com.au/forums/topic/437997-obd-scanner-to-ipad-application/ Share on other sites More sharing options...
M35woah Posted January 22, 2014 Share Posted January 22, 2014 (edited) HKS OB-link works great and it'll show CEL codes and such but you won't be able to clear them and it uses android.I think you'll have trouble to find an OBD scanner with wifi, the ones I've seen all use USB, serial or bluetooth. I don't use apple products and I understand that the ipad is what you probably what you have laying around, but it's probably easier if you get an android device with bluetooth. *EDIT* After I did a quick and easy google search this came up.... http://www.youtube.com/watch?v=EnPx4opR7o4 So a PLX kiwi device is an OBD scanner with wifi. But unsure how well it will work with the V36. Edited January 22, 2014 by M35woah Link to comment https://www.sau.com.au/forums/topic/437997-obd-scanner-to-ipad-application/#findComment-7177822 Share on other sites More sharing options...
LegionMe Posted January 22, 2014 Author Share Posted January 22, 2014 Anyone know what OBD ii / CAN protocol is used for the PV36-VQ35HR Any of these? ISO15765-4 (CAN) , ISO14230-4 (KWP2000) , ISO9141-2 , J1850 VPW , J1850 PWM, 11Bit CAN, 29Bit CAN Link to comment https://www.sau.com.au/forums/topic/437997-obd-scanner-to-ipad-application/#findComment-7177909 Share on other sites More sharing options...
MikeLo Posted January 23, 2014 Share Posted January 23, 2014 Check this out... http://www.kickstarter.com/projects/stanleyhuang/freematics-vehicle-telematics-with-open-source-har The OBD-II is already available, the kickstarter project is to raise money for the software. If you have minimal coding experience you could purchase the dongle right away and try it out. The goal is to build an Apple ios app that will.. Our goal is to implement following features in the App: Loading history data stored in Freematics OBD-II Adapter Illustrating collected data into more professional and fancy charts Video logging in sync with data logging Video replay with overlaid data Lap timer Car performance benchmarking and comparison Re-programming / updating firmware for Freematics OBD-II Adapter Link to comment https://www.sau.com.au/forums/topic/437997-obd-scanner-to-ipad-application/#findComment-7178349 Share on other sites More sharing options...
MikeLo Posted January 23, 2014 Share Posted January 23, 2014 This is a wiki from a guy with a 370Z has a lot of information about info he has got out of the Z http://bollen.us/NachosTikiWiki/tiki-index.php?page=2009+Nissan+370Z+CAN-to-USB+Hardware+and+Software Link to comment https://www.sau.com.au/forums/topic/437997-obd-scanner-to-ipad-application/#findComment-7178375 Share on other sites More sharing options...
MikeLo Posted January 23, 2014 Share Posted January 23, 2014 http://bollen.us/NachosTikiWiki/tiki-read_article.php?articleId=14 Useful links for different blogs that have done this stuff before. Link to comment https://www.sau.com.au/forums/topic/437997-obd-scanner-to-ipad-application/#findComment-7178381 Share on other sites More sharing options...
