Hey Guys,
Wrecking my R34 GTT rb25det NEO 5 Speed manual, in Melbourne south east sub
Its a complete car so just ask me if I haven't posted something you want or need.
Never thrashed well looked after car.
TXT or Call Luke 0413737028
Rb25det NEO engine done 65xxxxkm + loom + nismo tuned ECU $2,500 ono
Engine still in the car and running so you can check it out before you buy.
Turbo Smart T boost controller boosted to 10psi
Tuned at Chequered Tuning 2 Months ago making 206RWKW
5 Speed Gear box done 127xxxxkm $1,500 ono
Exedy Heavy Duty Clutch (only done 2000km) $500 ono
Interior:
Centre console full carbon fibre with 3 Gauge cluster Smoked Auto Gauges $400 ono
water temp, oil temp, oil pressure and Boost gauge in a separate cup holder.
Carbon Fibre Kick Plates/Door Sill Plates $50
Front seats $150 each
Back seat $200 ono
Steering wheel $150 ono
Door trims with no switches $100 each
Exterior:
White with Gold glitter pant work
Tommy Kaira Full body kit (cracked front bar but reparable) $450 ono
Brand new Bomex front bar that just needs spray and fit with brand new never fitted smoked indicators $450
Xenon HID light (one broken clip but has been fixed and sits perfect) $500
smoked side indicators $40
Carbon fibre eyelids $70
Nismo Carbon Fibre Pillar $40
Ray Volk look alike Mat Black Brand new put on only 2 Months ago (no scratches) $1,450 ono
18x8 Front with 235/40 ZR18 Nexen Tyres 2Months old
18x9 Back with 255/35 ZR18 Federal Tyres 2Months old
4X HSD coilovers G/C Ride well $500
Fiberglass R34 GTR wing (Black) $200
Rear tail lights $150
Performance:
R32 GTR brakes $450 ono
Aluminium Radiator $150 ono
FMIC 300x600 with custom piping so no holes need to be made in chassey (legal) $450
R33 GTR Turbo back 3" exhaust has some corrosion but repairable $250 ono
Heaps more just ask
if anyone needs specific photos let me know
Well I went through the last 10 R34 smics sold and the average price (including piping and ducting like the one I'm selling) was $135. Without the ducting and piping price was $110.
Would have thought $200 Ono reflected the average price of the item if someone were to make a slightly lower offer on it. Also 2 of those last 10 sold for $200. Maybe it was just an incredible time for demand vs supply on side mounts, who knows? Just did my research and selected a price I was flexible on but I thought reflected the market
Quick update
Still plenty of parts
For faster response txt or call Luke 0413737028
Rb25det NEO engine and clutch SOLD
Interior:
Centre console full carbon fibre with 3 Gauge cluster Smoked Auto Gauges sold
Carbon Fibre Kick Plates/Door Sill Plates sold
Front passenger seats $150ono
Back seat $150ono
Steering wheel air bag only $70
Exterior:
Xenon HID light (one broken clip but has been fixed and sits perfect) sold
smoked side indicators sold
Carbon fibre eyelids sold
Nismo Carbon Fibre Pillar sold
4X HSD coilovers G/C Ride well sold
Fiberglass R34 GTR wing (Black) sold
Rear tail lights sold
Performance:
FMIC 300x600 with custom piping so no holes need to be made in chassey (legal) sold
Heaps more just ask
besides mate. 200 bucks? are you on meth? they go for about 20-50. son of rajab son of rajab sunshine!
thanks mate ill pass.
what, that snorer smic not good enough for your 1.3L?
waaaaaaaaaaay to big. but will be good when i up the supporting mods :)
  • 1 month later...
Hey Guys,
another update
Interior:
water temp, oil temp, oil pressure and Boost gauge in a separate cup holder. $250
R34 Gtt manual cluster with 123km $150
R34 Nissan Skyline GTT 98 Centre 3 gauges $50
Back seat $150ono
Steering wheel air bag only $100
Door trims with no switches $100 both
Rear right and left plastic $30
Driver side and passengers side sun visors $30
Parcel shelf with 6x9 speaker cut out $20
Passenger side electric window switch $20
Glove box $35
R34 Nissan Skyline Airbag clock spring $50
Exterior:
Rear Windscreen Wiper Motor $30
Space saver with good tread $50
R34 Gtt fuel tank with fuel pump $260
R33 GTR Turbo back 3" (NO CAT) exhaust has some corrosion but repairable $150 ono
NISSAN SKYLINE R34 AC CONDENSER $120
Heaps more just ask
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
