Hey, so before anyone says use the search tool! I have spent pretty much the last week living on here and other websites while my car has been at a Mechanic who didn't find a solution, so i have the car back now
So I have an R33 GTS4 (Non turbo). I went for a drive the other day and sometimes whiling cruising there would suddenly be loss of power and it came back, then at most sets of lights and roundabouts when i came to a stop the engine cut out and stalled. Then i had trouble turning back over, only way to get going was giving it a lot of revs and looking like a complete tool. It's quite stressful and scary in heavy traffic.
I have searched and there could be a million different things that could be wrong and there is no point spending money replacing everything when it could be one simple thing. And a lot of forums end up talking about BOV problems which i don't have.
I recently put NGK iridium plugs in
Cleaned the AAC idle control
The mechanic Checked all vacuum hoses and the AFM (which has appeared to been opened and cleaned once already).
I new to skylines, I have no idea whats wrong, im just guessing all different things. I don't know what to look for.
Thanks in advance for help!
https://www.sau.com.au/forums/topic/438004-stalling-and-start-up-issues/
I'm pretty sure the AFM has been cleaned (has non-factory silicone around window suggesting it has been opened) , the mechanic checked it. Is it possible to check the CAS?
I tried starting up today, the first two times motor turned over started and then die straight away. Third time turned over idled roughly 10 minutes before stalling.
I have a R33 GTS-4 as well and I sometimes have the same issue, and I could never figure out why! Mine seems a little less serious though, mine will always start every time and wont backfire or cut out on idle. It only does it if I'm driving and I pull up to lights and pop it in neutral and brake, sometimes it will cut out. Sometimes if I start it back up straight after it will idle high (nearly 2k RPM) until i turn the car off and remove the key and wait a while. My car beeps 5 times after it is turned off too, I think it's the fuel pump that might do it, because my car is completely stock other than a Bosch 044 fuel pump which has been in since purchase, but I am no expert when it comes to cars.
The only way I avoid this issue is engine braking down gears to second and when pulling up to lights only putting it into neutral once its under 1k RPM.
Yeah it's a bit worrying when it's so random and in heavy traffic.
But I did order a consult port cable and plugged it in, and it brought up Code 12 : Mass air flow circuit. So I just ordered a new sensor should be here soon!
Because they're still worth a bit, I found a little information about the AFM so you can try fix the old one
Clean your afms - take them out, spray liberally with brake cleaner.
Then, resolder the PCB joints: if you look at the afm as it sits in the car, there's a big black square box bit on top of the AFM - facing you - the connector plugs into the side of this. This is the bit where the AFM pcb sits. It's filled with black silicon. Cut around the edges (carefully) with a sharp knife and remove the block of silicon. You'll then see the PCB with solder joints to the connector plug - these break down with age. Resolder them, and replace the silicon block with a dab of fresh black silicon goo.
Yeah for sure thanks.
I did some research into cleaning of the afms, as it appears that my old one has already been opened. It doesn't look like original silicon, looks like someone has played around with it.
Clean the AFM with CRC MAF Cleaner or Electrical Contact Cleaner. Use Nothing that will leave any oily residue on the internals.
Reset the ECU by disconnecting the NEGATIVE battery Terminal and hold/pump the brakes for 30 secs to use up any residual power in the circuitry.
maybe even turn on headlights etc, anything to drain power. Reconnect Battery. (if you have an alarm, disable it before you disconnect the Battery)
Sorry i haven't replied been smashed with homework and study. Replaced the MAF appeared to fix the problems. i just have a missfire now which i am pretty sure is the coilpacks. Thanks for everyone's help! :)
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
