Only used for 1,000 kms on an r34 gt-t, need to run minimum of an 18" wheel, selling as I put the factory brakes back on to sell the car. They felt amazing on the car, no squealing from the pads.
Condition is perfect.
$1,000, RRP is $2,000.
Paul
0438 182 855
What pads does it come with if any / will it fit 34 GTR / what size are the rotors / how many pistons do the calipers have ?
Thank you
- 356mm Ventilated & Slotted Rotors
- 8-Piston Calipers
- High Performance Pads
- Caliper Adapters
Not sure if they will fit 33 GTR sorry. Pads are as new, done approx 1,000 kms normal driving (no track use)
Edited by Motorman
  • 3 weeks later...
  • 3 weeks later...
  • 3 weeks later...
Shame I already have R34 Brembo on my car, otherwise I would have bought these!
BTW, you simply chuck 12mm helicoils on the calipers and use R33 Brembo bolts (M12x1.5 from memory).
If this falls through I'll pick them up , didn't get notified about the replies lol...
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
    • Absolutely. Look very closely at the photo (of yours) that I took my second snip of. See how the sill is thicker material right behind the pinchweld, where the two notches are? That is the factory reinforced area for lifting. That pad is supposed to carry the weight. The factory jack (go look at it, and how it interfaces with the car at the pinchweld) shows you exactly how the load is carried from the car to the jack to the ground.
    • if need be I guess I will, yeah. Just to be clear, it's okay to use the sill area around the jacking points for loading, meaning the actual pinch weld or jacking point just sits in the slot without taking on any weight?
    • No. No it can't. It will absolutely end badly. There's no need for it, so there's no need to create the risk. Mitigating a risk that didn't need to be there in the first place is even dumber than mitigating a risk that could be engineered out in the first place. And the risk has already been engineered out.
    • You can also make your own. It doesn't need to be rubber. It just needs to mate securely enough to whatever the jack/arm point is, and have a slot in the top. If that means welding a few chunks of steel together, or slotting something in a mill, then, that's what it means.
