Forgive the terminology, maybe I will get it later on
Well bs is still alive in the carsales industry and why am I supprised :verymad:
The R34 I am buying that was supposed to be able to be tuned to 700HP to 800HP could not make 400HP. It could not get enough boost to kick the turbo off.I think he said it was only about 12 lb., it was about 200KW :(
Had it on the Dyno today and found out I need a turbo boost controller and new cam once the turbo controller was installed to be able to take the power it was capible of acheiving , Mmmmmmm :verymad::yucky:
Trouble is learning can be an expensive business :pirate: Grrrrrrrrrr!
https://www.sau.com.au/forums/topic/438031-honest-car-salesman/
What makes you think you can achieve 700+ HP? What Turbo are you running? Is that your engine bay in your avatar? looks like you have a high mount single?
Going from 200KW to 350+ with just a change of boost controller is highly doubtful... Unless you can tell everyone what the specs are of your engine...
Thanks for your input guys, I have paid the deposit and signed the contract, I am not worried about that, the car is worth it to me, I just get sick of being crapped to.
The motor work was done by Croydon Racing Developements and from what I found out about them they know what they are doing.
The car had $42K SPENT ON THE MOTOR , too many things to write and most of it I do not understand but here are some of the mods; GikenT78 Single turbo kit, OS quad Clutch, push /pull kit, Koyorad radiator , custom made catch tank, Z32 air flow meter', ,nitto h beam connecting rods; je/nitto rb 26 forged pistons, nitto rb series high volume oil pump, 9 lt sump conversion, machine work on engine block, engine rebuild- hand file rings ect, bosch fuel pump ; and all of the other bits and peices that needed to be done.
That is not counting stuff that Advan Performance did, I think they know their stuff.
So there was alot of money spent and the work was done by people in the performance business. I feel OK about the car, well I love it :thumbsup:
I do not know very much about getting a R34 up and running and I maybe wrong, but 600HP, I will soon find out?
Some of the parts should give someone an idea of the type of work done on the engine, no thoughts on what was done to the engine can get up to 600hp ?
When the cam and boost control have been fitted and after the final tune mid next I will take a photo of the Dyno readout and post it
A bit late it seems.....
They just added the Boost controller and Dyno done, 338 AWKW ,so nowhere near the sales pitch talk.
Spoke to the bloke at CRD and he said it is a good unit and if I wanted more from it i would need to update the fuel system and a new cam and they could lift the performance, think that will be enough for me for a while and see what I want to do in the future .
So I will pick it up on Saturday and see how it goes on the 330 kls ride home , should be fun :action-smiley-069:
Normally when those figures are thrown around it means that the engine is capable of making that power given all the supporting mods are in place.
You clearly didn't do much research into what you bought, u just saw a big parts list n they told you this n that and you were none the wiser.
Without a complete fuel system including surge tank and external pumps it's never realy gona make over 400kw (540 hp).
Mine maxed out at 401kw
Also a fuel system from croydon is not cheap, I know from experience as they built mine.
So unless your going to spend cash on a fuel system and upgrade to e85 your not going to see over 550hp
Also who builds a forged motor with all that and doesn't even put in a simple boost controller?
Also a Gtr has camshafts (there is 2 of them)
If it didn't have a set of basic aftermarket cams in there all ready then I'd take it that no head work was carried out at all and now even less likely to make 7-800hp
also 800 at the wheel/ dyno hp is a f**king monster. do you want that sort of power, do you understand what that is like to drive and maintain?
if you get a solid reliable 450-500 atw then you have got to be happy.
sorry to say it again but if your not sure on whats what with the parts list then a 7-800hp car might not be the best idea to chase.
do you like driving it? is it a good car? then drive it love it and be happy with a good purchase.
i can say my rb25 is capable of 800hp.......with $200k
Edited by GH05T
Ontop of that it would be boring as hell to drive everyday as with that power you are not seeing boost in the rpm you spend most your time in on the road, when I drove a 500kw gtr on the road it really felt boring compared to a 350kw one that is until you go past 5-6k lol.
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
