I think you might be surprised as to how much difference there is between the two gearboxes. Don't forget the S15 has a turbo, so the torque output is pretty high.
Nevertheless, I would vote for the Z car box over the S15 box. I mean, people with S15s were famously replacing the 6 speeders with 5 speeders because the little SR20 5 speeder was stronger.
Maybe, I am not really familiar with the s15 boxes. But my observations have always been that gearboxes suffer the most stress and damage when they are suddenly shocked with lots of torque in a small space of time. The sr20 engine doesn't really fit into this category, even with a turbo. Sure torque output on an turbo s15 can be high, but its usually up high and once the clutch engages and everything starts building momentum the stress on components is much more linear and manageable.
Driving like an idiot is not accounted for of-course. That's why you get lots of broken drive train components and mounts because people are dumping the clutch on wide after-market wheels with grippy tires and high output engines on cars that were never designed to handle that kind of abuse.
Edited by sonicz
Will a 350z box Bolton the R34gtt though also are they any stronger than Rb25 boxes. Could be a good mod for economy and possibly higher speeds.
And no it won't bolt on. Assuming that they are common with the big frame Nissan 5 speeders (big assumption, almost certainly wrong), you have to build up a box using appropriate front and rear halves. Otherwise you're into the territory of using adapter plates. I'm pretty sure that this is how it has to be done. Plenty of VQ into R chassis conversions using the original R chassis gearbox have been documented with adapter plates, and I don't think I've ever heard of someone Frankensteining two halves of the different gearboxes together.
Frankensteining can be done with VG gearboxes, because only the bellhousing half of the box is different.
  • 5 months later...
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
