I got the Rs4-S serviced yesterday and the mechanic picked up a few issues:
  • Front rotors need replacing
  • Rocker cover weeping oil
  • Front steering joints worn
  • Rear hicas joints worn
Nothing too serious, but I'm just looking for some input as to the best way to address these things, part recommendations etc. It has R33 gts-t brakes on it, so the rotors shouldn't be too hard to replace.
Cheers for your thoughts guys! :thumbsup:
https://www.sau.com.au/forums/topic/438056-a-few-issues-picked-up-at-service/
Steering joints? As in inner or outer tie rods?
They're not too hard to do, though it can take some patience and some ingenuity to pop the outer tie rod tapered pin out of the knuckle.
I use outer tie rods which I purchased off ebay from a taiwanese seller. They were cheap and they've been fine.
I purchased some GTR inner tie rods from supercheap auto. They needed to be trimmed by about 1.5 cm on the threaded ends. This leaves the maximum amount of thread in the outer tie rod. Some tie rods on the market are generalised between gtr/gtst/stagea etc. Dont use inner tie rods which are too short otherwise you risk them stripping out and causing a major accident.
Edited by zoomzoom
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
