shizzmoo Posted January 24, 2014 Share Posted January 24, 2014 R33 gts-t all stock, would I get more power from a pod filter, stock air box with K&N or stock air box with stock air filter, Im fitting new font mount and just wondering? Link to comment https://www.sau.com.au/forums/topic/438078-pod-or-stock-air-box/ Share on other sites More sharing options...
Missileman Posted January 24, 2014 Share Posted January 24, 2014 http://youtu.be/PAIxeQUSg-Q Link to comment https://www.sau.com.au/forums/topic/438078-pod-or-stock-air-box/#findComment-7179275 Share on other sites More sharing options...
shizzmoo Posted January 24, 2014 Author Share Posted January 24, 2014 Awesome!!! Link to comment https://www.sau.com.au/forums/topic/438078-pod-or-stock-air-box/#findComment-7179289 Share on other sites More sharing options...
Dose Pipe Sutututu Posted January 24, 2014 Share Posted January 24, 2014 stock airbox & a good panel filter brah still flutters like a slart lol Link to comment https://www.sau.com.au/forums/topic/438078-pod-or-stock-air-box/#findComment-7179296 Share on other sites More sharing options...
scotty nm35 Posted January 24, 2014 Share Posted January 24, 2014 I have seen 500kw through a cotton panel filter in a stock GTR airbox, unless you are looking to squeeze every last kw out of your setup the stock airbox will work fine. You will need to upgrade the rubber intake though. If you lay a paper element out flat, it has over twice the surface area of a pod, or K+N panel, so any flow gains from a less restrictive filter material are lost due to the larger/less pleats. Link to comment https://www.sau.com.au/forums/topic/438078-pod-or-stock-air-box/#findComment-7179365 Share on other sites More sharing options...
hypergear Posted January 24, 2014 Share Posted January 24, 2014 No panel filter + Bunch of 1.5 inches holes on the Air box lid. Link to comment https://www.sau.com.au/forums/topic/438078-pod-or-stock-air-box/#findComment-7179398 Share on other sites More sharing options...
Dose Pipe Sutututu Posted January 24, 2014 Share Posted January 24, 2014 I wonder it's easy enough to fit a R33 GT-R airbox into a R33 GTS-t they have that awesome side part which allows for more airflow and the scoop is larger Link to comment https://www.sau.com.au/forums/topic/438078-pod-or-stock-air-box/#findComment-7179404 Share on other sites More sharing options...
GTSBoy Posted January 24, 2014 Share Posted January 24, 2014 They also have two smaller holes for AFMs........ Link to comment https://www.sau.com.au/forums/topic/438078-pod-or-stock-air-box/#findComment-7179433 Share on other sites More sharing options...
shizzmoo Posted January 24, 2014 Author Share Posted January 24, 2014 Awesome responses guys cheers, I will keep the stock air box and filter, I'm only running stock turbo and boost. I hear a lot of people saying pods are better, I put a cheap 1 on and I did instantly feel a small lack of power and a small flat spot until the computer sorted it out Link to comment https://www.sau.com.au/forums/topic/438078-pod-or-stock-air-box/#findComment-7179434 Share on other sites More sharing options...
Sklyn Posted January 24, 2014 Share Posted January 24, 2014 research will be your friend.. search functions will answer your questions and allow you to make your own decision, while teaching you something in the process. =) Link to comment https://www.sau.com.au/forums/topic/438078-pod-or-stock-air-box/#findComment-7179566 Share on other sites More sharing options...
Dose Pipe Sutututu Posted January 24, 2014 Share Posted January 24, 2014 They also have two smaller holes for AFMs........ Of course I'll block one off, duh! Link to comment https://www.sau.com.au/forums/topic/438078-pod-or-stock-air-box/#findComment-7179768 Share on other sites More sharing options...
