I have seen 500kw through a cotton panel filter in a stock GTR airbox, unless you are looking to squeeze every last kw out of your setup the stock airbox will work fine. You will need to upgrade the rubber intake though.
If you lay a paper element out flat, it has over twice the surface area of a pod, or K+N panel, so any flow gains from a less restrictive filter material are lost due to the larger/less pleats.
Awesome responses guys cheers, I will keep the stock air box and filter, I'm only running stock turbo and boost. I hear a lot of people saying pods are better, I put a cheap 1 on and I did instantly feel a small lack of power and a small flat spot until the computer sorted it out
