hi guys , problem, ive gone to install rack spacers in an r32 and it seems the teeth on the shaft wont allow it to go in further????
it gets to the rack and stops flush and feels like the teeth are maxing? the other side goes in HEAPS!! anybody had this problem before?
https://www.sau.com.au/forums/topic/438079-lock-spacers-not-working/
yea man droped both sides so just the rack. have done this on my c33, albeit with some other over the top mods and no probs. will chuck pics tomorrow . measurements at a guess would be 2mm below flush on drivers/pinion side and 20-25mm on other
Edited by missile_c33
Yeah if thats what your getting then you need to run the offset spacers like these ones.
http://www.gktech.com/index.php/4130-high-tensile-steel-steering-rack-spacer-set.html
so you will put the big spacer on the passenger side since it has more travel and small spacer on driver side then you just recentre the rack to even it out.
Recentreing is simple. First install those offset spacers plus your tie rods, then go lock to lock and coubt the turns it takes then go back half way and that will be your new centre position for your rack.
You now set your toe settings from this new centre position.
Edited by boostn0199
oh yea, i know that (haha) it just seems to run out of teeth to pull the drivers wheel in, ill take pics and try get them up on here
Yeah thats why u recentre it so in other words after you recentre it the rack wont be at equal lengths at each side to compensate for the extra travel on one side.
For example like you said you have 3mm travel on your drivers side and say 12mm on your passenger side. If the rack is left in its centre position like normal you will get more lock and one side due to the extra travel so when you recentre it to its new centre position which would be 4.5mm off the normal centre towards the drivers side you will now have 7mm travel each side asappose to before where it was 12 on one and 3 on the other.
I know its hard to understand from reading it but might help if I draw a diagram.
yea makes sense and REALLY appreciate the help, what i shood have said also is im using offset rack spacers. so when i go full lock right, with offset spacer on, lock nut off tierod and wound right in (cut to go all the way) so everything in as far as possible, it doesnt hit lock stops, maybe no use offsets or affter market tierods?
I had the same problem with my 33 well all 33 seem to do it when you add washers for more lock.. I think its just in the design of the rack, turning left always has more travel. If just got my knuckles modified, were they shorten and straighten the tie rod arm(cut and weld) gets heaps of lock combined with a slip on washer. The advantage is it reduces akerman between the two wheels and also shortens the steering ratio(less turns lock to lock. Win win for a drifter. JDI fabrications do them in Melbourne.
Really your 33 rack does that? The 6 ive gone through all only have 4mm extra travel each side.
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
