hi guys , problem, ive gone to install rack spacers in an r32 and it seems the teeth on the shaft wont allow it to go in further????
it gets to the rack and stops flush and feels like the teeth are maxing? the other side goes in HEAPS!! anybody had this problem before?
https://www.sau.com.au/forums/topic/438079-lock-spacers-not-working/
yea man droped both sides so just the rack. have done this on my c33, albeit with some other over the top mods and no probs. will chuck pics tomorrow . measurements at a guess would be 2mm below flush on drivers/pinion side and 20-25mm on other
Edited by missile_c33
Yeah if thats what your getting then you need to run the offset spacers like these ones.
http://www.gktech.com/index.php/4130-high-tensile-steel-steering-rack-spacer-set.html
so you will put the big spacer on the passenger side since it has more travel and small spacer on driver side then you just recentre the rack to even it out.
Recentreing is simple. First install those offset spacers plus your tie rods, then go lock to lock and coubt the turns it takes then go back half way and that will be your new centre position for your rack.
You now set your toe settings from this new centre position.
Edited by boostn0199
oh yea, i know that (haha) it just seems to run out of teeth to pull the drivers wheel in, ill take pics and try get them up on here
Yeah thats why u recentre it so in other words after you recentre it the rack wont be at equal lengths at each side to compensate for the extra travel on one side.
For example like you said you have 3mm travel on your drivers side and say 12mm on your passenger side. If the rack is left in its centre position like normal you will get more lock and one side due to the extra travel so when you recentre it to its new centre position which would be 4.5mm off the normal centre towards the drivers side you will now have 7mm travel each side asappose to before where it was 12 on one and 3 on the other.
I know its hard to understand from reading it but might help if I draw a diagram.
yea makes sense and REALLY appreciate the help, what i shood have said also is im using offset rack spacers. so when i go full lock right, with offset spacer on, lock nut off tierod and wound right in (cut to go all the way) so everything in as far as possible, it doesnt hit lock stops, maybe no use offsets or affter market tierods?
I had the same problem with my 33 well all 33 seem to do it when you add washers for more lock.. I think its just in the design of the rack, turning left always has more travel. If just got my knuckles modified, were they shorten and straighten the tie rod arm(cut and weld) gets heaps of lock combined with a slip on washer. The advantage is it reduces akerman between the two wheels and also shortens the steering ratio(less turns lock to lock. Win win for a drifter. JDI fabrications do them in Melbourne.
Really your 33 rack does that? The 6 ive gone through all only have 4mm extra travel each side.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
