hi guys , problem, ive gone to install rack spacers in an r32 and it seems the teeth on the shaft wont allow it to go in further????
it gets to the rack and stops flush and feels like the teeth are maxing? the other side goes in HEAPS!! anybody had this problem before?
https://www.sau.com.au/forums/topic/438079-lock-spacers-not-working/
yea man droped both sides so just the rack. have done this on my c33, albeit with some other over the top mods and no probs. will chuck pics tomorrow . measurements at a guess would be 2mm below flush on drivers/pinion side and 20-25mm on other
Edited by missile_c33
Yeah if thats what your getting then you need to run the offset spacers like these ones.
http://www.gktech.com/index.php/4130-high-tensile-steel-steering-rack-spacer-set.html
so you will put the big spacer on the passenger side since it has more travel and small spacer on driver side then you just recentre the rack to even it out.
Recentreing is simple. First install those offset spacers plus your tie rods, then go lock to lock and coubt the turns it takes then go back half way and that will be your new centre position for your rack.
You now set your toe settings from this new centre position.
Edited by boostn0199
oh yea, i know that (haha) it just seems to run out of teeth to pull the drivers wheel in, ill take pics and try get them up on here
Yeah thats why u recentre it so in other words after you recentre it the rack wont be at equal lengths at each side to compensate for the extra travel on one side.
For example like you said you have 3mm travel on your drivers side and say 12mm on your passenger side. If the rack is left in its centre position like normal you will get more lock and one side due to the extra travel so when you recentre it to its new centre position which would be 4.5mm off the normal centre towards the drivers side you will now have 7mm travel each side asappose to before where it was 12 on one and 3 on the other.
I know its hard to understand from reading it but might help if I draw a diagram.
yea makes sense and REALLY appreciate the help, what i shood have said also is im using offset rack spacers. so when i go full lock right, with offset spacer on, lock nut off tierod and wound right in (cut to go all the way) so everything in as far as possible, it doesnt hit lock stops, maybe no use offsets or affter market tierods?
I had the same problem with my 33 well all 33 seem to do it when you add washers for more lock.. I think its just in the design of the rack, turning left always has more travel. If just got my knuckles modified, were they shorten and straighten the tie rod arm(cut and weld) gets heaps of lock combined with a slip on washer. The advantage is it reduces akerman between the two wheels and also shortens the steering ratio(less turns lock to lock. Win win for a drifter. JDI fabrications do them in Melbourne.
Really your 33 rack does that? The 6 ive gone through all only have 4mm extra travel each side.
    • it was good to see our presence at GTR festival..hope to see more SAU at these events
    • This is awesome.
    • Thanks for the quick replies guys its appreciated. A small extension was welded onto the standard 6boost external gate pipe which you can see where the pipe goes from black to stainless just below and to the right of the rear housing in the first picture. Overall I would say the flow is pretty good other than 6boosts choice to come straight off the collector at a decent angle.. Not sure why I went with two valves, I originally replaced the stock twin bovs with the GFB when I had the twins on. When I purchased the EFR it came with the Turbosmart Kompact BOV so I figured that would be a better option than the stock EFR Bov. I don't believe the Turbosmart BOV is adjustable? When I get the spike and then sudden dip in boost pressure, the turbo speed does drop as well. Stock head size wise however I believe it has Neo Turbo springs and a Neo Turbo intake camshaft and an aftermarket exhaust camshaft in the vicinity of 260 degrees. We didn't try a different MAC valve, we tried two different ways of plumbing it and we also tried removing the mac valve entirely and just having the boost source from the turbo directly connected to the wastegate and it still spiked / dropped and exhibited the same behaviour. Standard R33 GTR 5 speed tansmission. I'm running a Haltech Elite 2500 and can provide some logs if you. I understand what you're saying in that it looks like an auto plot however no, it's still a manual and it just has a lot of torque down low, for all intents and purposes it's a very impressive street car. I've attached a photo of the quickbitz dyno plot which was when the only difference is I was running -5 twin turbos with a mac valve. As you can see theres a decent dip in AFRs between 125kmh and 135kmh. Our problem now is not that the AFRs are dropping, just the boost pressure is dropping, however it is evident in the same RPM range of the map, coincidentally or not.
    • What transmission are you running?  It's a bit tricky with the scaling, but at face value the power "curve" looks more like a "line" which is a bit odd... basically a lot more like a dyno plot I'd expect with a highish (compared to a factory auto) stall torque converter type setup. If this is running an auto then this kind of boost control challenge is definitely a thing, the rpm scale on the dyno doesn't reflect what the engine is actually doing (unless the dyno has access to the engine's ACTUAL speed electronically) and what you'll get is a big rpm flare up as the engine torque launches past the converter pump's ability to resist torque at that rpm, then as the converter starts picking up rpm it will kinda even out again and the engine rpm will pick up more steadily. The trick with this "flare up" is if it's kinda near the boost threshold for the turbo then the engine's airflow requirements to maintain the previous boost level will outrun the turbo's ability to supply that boost - so you end up with a natural flattening off, if not dip when that happens.   If you are running closed loop, or even tune the "feed forward" wastegate duty cycle to deal with that rpm spike then when the engine starts settling to a more typical climb you'll actually have a situation where the gate is "too closed" and boost will run away for a bit, then have to pull down again.      It's not trivial to get this perfect as most boost control systems are generally expecting more predictable engine rpm rates of change, but if you *know* that's whats going on then you can at least "accept your fate" and realise getting that area perfect is kinda chasing your tail a bit, and assume that if the rest is working sensibly and the spike/dip isn't completely uncontrolled then you should be good. Sorry if I've gone off on a tangent, but the dyno plot and boost control behaviour look a LOT like what I've seen tuning autos in the past. What ECU are you running? Could possibly be convinced into looking at logs if I get too bored this weekend haha.
    • A few things that seem a bit off here. - why is there 2 BOV’s?  - the turbo smart BOV on the compressor housing, is it turned up ALL the way? I have seen this become an issue on old man Pete’s car. It would push open and recirc, turbo speed would rise and the boost pressure would do weird things. - stock head? Does that include springs? - tried a different MAC valve? Is it plumbed correctly?
