Hey All,
My names Michael and I used to own a maroon R33 GTST 5 years ago and be fairly active on the forum. I used to attend the meets up on the central coast at maccas all those years ago!
Have recently purchased a black R33 GTST S1. Got it for an absolute steal and its fairly standard and neat and tidy. I plan to modify it slowly over the coming months and keep everyone informed with a few pictures and updates :)
Hope to get involved again in this forum and get out and meet a few more SAU-ers.
Thanks!
https://www.sau.com.au/forums/topic/438081-old-r33-owner-buys-r33-again/
This morning I pulled out the coil packs and did the old tape job to stop misfire in high rpm.
I also discovered a manual boost controller hidden below the air box! The standard solenoid was still int eh engine bay with tubing connected going no where.. So that's a score!
I wound down the boost from 13psi to 10psi and I am getting a much cleaner run through the entire rev range now with no misfires or jerkiness.
Next plans are to re-connect the audio system up and replace the rear speakers that are fu$&ed.
Remember the common issues and fix them :)
- replace coils with OEM or Splitfires
- Replace exhaust manifold studs with uprated toyota ones/oem
- rocker cover gaskets and half moons
- clean your aac and cold start valve
Thanks for the tips.. Actually in the process of buying splitfire coil packs now. 2 out of 6 of my oem coil packs have 1 stripped bolt each so they will be a bitch to get out :(
Also just updating a few other bits:
# replaced the rear speakers that were all cracked, rewired all speakers and head unit/DVD player that was in the car so everything now works.
#bought a second hand 4 ch kicker amp to run all speakers, much better sound now, worth the $50 :D
# found my old his type 1 turbo timer and installed that.. Works perfect, If anyone needs the wiring colour code to the ignition let me know :)
That's about it for now...
I will be doing a full service of all liquids and oils and filters and replacing my coil packs with split fires next weekend :D
Yepo gota love the design of the tail lights...
Installed my apexi el II boost gauge and controller tonight. It is all lit up and working with the controller just need to run the sensor wire through my firewall back to the controller. Boost line is already taped.
Few pictures of my gauge install and my turbo timer install a couple of days ago.. Plus my head unit "tidy up" in the background!
  • 3 weeks later...
welcome back.
loving the progress reports.
Thanks Luke!
Well I swapped over my coil packs... Seems that the coil pack in cylinder 2 had been swimming in coolant at some point in its life. As you can see in the picture by the white crust, there is no evidence now of any coolant leaks after running my car for 1000km then checking on my new yellow jackets.
Its amazing the difference that yellow jackets have made right across the rev range, everything seems so much smoother now and no more misses at any rpm!
In the mean time I also managed to pick up an 18" set of used rims and wheel package! 2 of the rims had some decent gutter rash but was able to sand them back and spray with matt black paint and they look fine now. All 4 have 90% Bridgetsone tyre left on them and they cost me only $200. Bargain....
Pictures:
  • 1 month later...
Had a weekend off work so I took the time to install some of the mods I have had siting in my garage for a while Pictures are attached of the various mods, worth noting I installed everything myself with a mixture of my own knowledge and Google/this forum
· FMIC Kit
· Drivers side seat upgrade
· Conversion Speedo/Cluster kit
· HID low beam and HID Hi beam (8000k colour temp)
· Complete LED conversion of all exterior globs (parkers, all indicator globes, reverse lights, number plate lights etc)
· LED conversion to interior dome light and map lights + I have a blue conversion kit for my Aircon buttons still to be installed.
I took a fair few pictures while installing a lot of these mods which I am happy to do a write up and post for anyone who wants it
Stay tuned in the coming weeks for the following mods:
· Converting the clock plus aircon displays to blue (using acrylic gel) plus replacing the aircon buttons to blue LED
· Interior blue lighting in foot wells when doors open (courtesy lights)
· Installation of new LED indicator units
· Engine bay tidy up with new blue colour hosing and conduit..
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
