Hi all , just wanted to share my detailing experience and some photos with you guys. My GT-R had foggy lights , swirl marks everywhere and I'd wanted to give it a good clean since I've never detailed it properly since i bought it .
Took it to a place called Affinesse (VIC) , Jerald the owner talked me through the processes involved and after seeing some of his previous work i quickly booked the car in for a well deserved luxurious bath.
Here are some of the pictures , most of them are of the actual detail process and then a little photo shoot that comes with the premium 3 stage detail.
Photos are taken by Affinesse and the captions are written by Jerald .
Wheel Woolies x Sonax Full Effect Wheel Cleaner
Optimum Car Wash x CT18
Prepping the 50/50
HD Cut x BnS Microfibre Cutting | M205 x LC Black
Took out the side indicators to clean behind
Clear runs on the bumper. 1 of 3.
Wet sanded with 1200, 2000, 4000 and then polished
Before correction
The BBS logo was a bit cloudy
Polished with HD Uno x LC Black
The rear lights had been heavily oxidised
So they needed a bit of a wetsand. Exact same process as headlight restoration.
50/5- wait...70/30?
Such a little detail really adds back visual value to the car
Applying Sonax Premium Class Carnauba via Dodo Juice Finger Mitt
Optimum Edgless - Always the MF of choice for me.
I was stunned by the gloss and depth of the Sonax Carnauba (especially on the fender). And that was just after one coat.
https://www.sau.com.au/forums/topic/438087-extreme-detail-99-bnr34-gt-r-v-spec/
And so begins the night photoshoot. I was feeling like doing something different this time. Different colour tones and more vintage effects.
Of course, as a fellow GT-R enthusiast, a tribute to Paul Walker - May he rest in peace.
At 5 in the morning, I became engrossed in the taillights.
After the car meet, we recooped for a daytime shoot
I was surprised I was able to capture the metallic fleck on a 17-55mm Lens rather than my usual 100mm Macro. The wax just kept on impressing.
Wheels coated with Finish Kare FK1000P, Tyres with HD Tyre Gel
Normally I'm a big fan of Optimum Opti-Bond due to it being water-based and low-gloss, however the HD Tyre Gel is simply amazing if you want high gloss. After very high speeds, we found absolutely zero sling on the tyres.
I was amazed at the results after seeing it in person .
Thanks everyone for reading
Edited by xtermin8or
  • Like 3
  • 3 weeks later...
Epic result, I think I need to get me a tub of that Sonax wax. The wheel cleaner is excellent too, bought some a while ago, doesn't stink as bad as some other similar products
Wetsanding is basically sanding the clear coat with really fine sandpaper and water for lubrication. Works great for taking off blemishes or flattening "orange peel" that some cars either have from factory of after paint repairs. But, wouldn't recommend anyone trying it (if you haven't done it before) without some practice on scrap panels first, especially around sharp creases and edges, doesn't take much to go thru the clear if not very careful
Edited by junkie
Cheers mate
So its normal sand paper just really fine grit? Does it produce a better result than using the clay bar?
fark im a noob i did two similar replies to this topic
Cheers mate
ill try explain it... claying is more of a maintenance thing, while wetsanding is defect rectification.
clay will only remove the crap thats stuck to your clear coat, stuff like brake dust, tree sap, etc but it wont fix any issues with the paint itself. its also pretty genetle on the paint, if done properly
wetsanding on the other hand, its more of an extreme method of fixing paint defects like deep scratches, clear runs and orange peel. its normally used in place of machine polishing for a smaller area to save time and effort. and since it takes off a thin layer of clear everytime, its not something you want to do often. plus, machine polishing is needed afterwards as youre left with a matte surface. if you want to try it yourself, id suggest buy a scrap panel from a wrecker, then get some 1500/2000/2500/3000 grit paper and go nuts.
Cheer man, makes sense
  • 4 weeks later...
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
