Hey guys so I'm Taylor and I'm from Alberta Canada. I'm new to the site and I'm looking at doing my first build on a R32 GTR. The engine has just under 80k on it and is sitting bone stock but it runs perfectly with no issues. The cars only problems are minor dents and peeling paint. It also needs some interior work as it's missing rear window sill cover and air vent covers. I'm looking for any advice you would all be able to give as far as costs of the paint job and fixing the dents (I know it will be no less then 4000) I'd also appreciate suggestions of good sites to visit to but parts! Finally I haven't decided where I want to take this car as far as the actual engine build any ideas suggestions or advice would really be appreciated !! Thanks! I'll upload some pictures as soon as I get the chance to give you guys a better idea of what I'm talking about!
https://www.sau.com.au/forums/topic/438104-r32-paint-job/
Hi Taylor, ever thought of doing it yourself?
I like to DIY as much as i can, so my opinion is biased. And being in Australia i cant guess how much they charge for painting over there in Canada.
Anyway..... the GTR has alloy front guards and bonnett, maybe other bits too, so you would have to be careful, because its so soft.
Have a look at Youtube for some expert advice, also you can see how much work is involved.
I like this guys vids.........http://www.youtube.com/user/restolad?feature=watch
Donnie Smith is another good one.
DIY can be very satisfying, and much cheaper.
But there is the risk of running into difficulty or doing a bad job, so dont tackle it if your not confident and determined.
And as with everything in life; education will help you make a good decision.
:thumbsup:
https://www.sau.com.au/forums/topic/438104-r32-paint-job/#findComment-7181316
  • 1 month later...
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 馃槀
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
    • also, we need to know which solution worked....
