Hello guys, I'm coming off my Ps in March and I'm looking at getting myself a nice R33 GTR as a Friday/Weekend cruiser, I don't know if my budget is high enough but I'm looking at spending $20K.
My only concern is trying to find a stock one in good condition, I don't really want any pre modified ones.
Can you guys help me and give me an idea on what to look out for?
Also whats the difference between the normal GTR and a VSpec one?
Thanks much guys.
https://www.sau.com.au/forums/topic/438132-looking-at-a-r33-gtr/
There is a huuuuuuge thread on what you should look for when buying a skyline. Have you tried googling it?
And if you want a "unmodified" one. Then contact iron chef on here and he will actor to your budget and get you what you want.
Stay away from parramatta road if you are in NSW.
  • Like 1
They're like any other ageing vehicle. Things get worn out and need replacing. Because of the GT-R's high performance nature, it can be a bit expensive.
Look for one with a decent service history since it landed and evidence it's been loved and treated correctly. They're not overly unreliable but they are old.
There goes a saying; If you can afford to buy two GT-Rs, then you can afford to run and maintain one.
My R32 GT-R has cost me about $6000 in basic maintenance and repairs in the last 12 months and that's no modding included.
^Hence get whatever one you buy inspected by a trusted workshop and compression tested.
They drive like a RWD car.
I did but it's just replacing things with genuine nissan parts, replacing things that break and a clutch.
It all adds up pretty quickly. They're definitely not a cheap car to own by any standard.
You get what you pay for.......
Personally if you are preparing to spend less then $20K on an R33 GTR, I think you will struggle.
Realistically, for something that won't give you ongoing trouble, $30K is the minimum you should budget. If you spend less on purchase, you will just spend it a bit later on repairs and maintenance....
If you can't afford that as a minimum (and remember to budget for ongoing costs like insurance ($1000+ p.a.), 98RON+ petrol ($100+ per fill), regular service and fluids ($300-400/qtr), rego etc....) then stay away - you'll just be dissappointed......
If you can afford it - its the best car owning experience there is.....
to buy a car - I'd recommend importing from a reputable importer (see separate thread) - it's your best chance to find something meeting your taste,budget and requirement.
Good Luck
Cheers
The Baron
Rule of thumb for purchasing any used/ageing/old sports car.
Take the purchase price and double it.
If you aren't able to do this, forget about getting said vehicle.
I'm not saying you will use all that money just keeping the car on the road but the extra money will give you plenty of reserves to cover worst case scenarios.
If you happen to get a really good car that doesn't dig into your savings, use that money as a deposit for a house instead...Win Win ;)
Wow. how many scare tactics are in this thread.
I'm sure old mate is aware about fuel costs and insurance. however $400 a quarter for servicing? Are you changing the timing belt every quarter?
In all seriousness, if you travel 5000km every quarter that is one oil change and filter. Even if you travel double that (which is a daily GTr) then you'd need 2 oil changes. diffs and gearbox would only need yo be done annually if you are travelling 30 000+ km a year.
Unless you are getting ripped on oil for your car or you're for some reason taking it to a BMW dealer then I see no way how it would cost a 130 a month in services.
And the market I've been seeing is clean examples of 33's in the 20-25k budget not the 30+
Unless you regard that one 33 from parramatta road with something stupid like 30,000km on it for 33k. BTW which was a r grade import.
End ramble
I guess I should qualify - I allow $150 /month for servicing costs over the year to cover all the things that might crop up. This includes the regular oils and fluids but also an allowance for all the stuff that a 15-20 year old car accumulates.....and which frankly I am not skilled enough to fix myself.
For example the clutch coil on my a/c compressor is on the way out (a common problem in an R32) - thats a $400 job the get done this year requiring an auto electrician.
I'd rather be conservative and realistic then to say "oh its only an oil and grease change every 6 months".
just my 2 c ;-)
Cheers
The Baron
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
