I tried this - water didn't really bubble. A tiny amount of white froth developed as the coolant started to get hot. Not sure if that's meant to happen but I read up that it froths a little when the radiator starts to build up pressure.
Massive head f**k it has become!
that sound about right and my best guess is HG, just enough to upset the cylinder pressures
I have a feeling it's the injector. Are you sure they're brand new? I bought the fiveo 1000cc injectors and they are 2nd hand high flows and one even had surface rust. I wouldn't recommend the high flows really. It can be difficult to cold start my engine now.
I might buy a block tester to check your theory! Thanks for your advice...
Yeh they were brand new. Even looked new - I knew they were shit injectors but needed something temporarily. You guys think it's a good idea to remove the first injector and then plug it in and crank car over to physically make sure petrol is getting squirted out of the injector? A bit of a big job to swap 1st and 2nd injectors as they are side feed and I'd have to remove the plenum.:)
Yeh they were brand new. Even looked new - I knew they were shit injectors but needed something temporarily. You guys think it's a good idea to remove the first injector and then plug it in and crank car over to physically make sure petrol is getting squirted out of the injector? A bit of a big job to swap 1st and 2nd injectors as they are side feed and I'd have to remove the plenum. :)
id defiantly give it a go, worst case after you pull everything out is that It works, then you know the injectors wont be the issue..
my old pulsar was misfiring on 1st cylinder, replaced leads, plugs, did a compression test, exc.. it was a little water in the dizzy cap... got nothing to do with rb`s but it was just a simple problem...
Edited by ..::R33GTS-T::..
  • Like 1
I might buy a block tester to check your theory! Thanks for your advice...Yeh they were brand new. Even looked new - I knew they were shit injectors but needed something temporarily. You guys think it's a good idea to remove the first injector and then plug it in and crank car over to physically make sure petrol is getting squirted out of the injector? A bit of a big job to swap 1st and 2nd injectors as they are side feed and I'd have to remove the plenum.:)
Won't there be a huge hole in the rail if you pull one injector out?
You can change injectors without taking plenum off just need to take T/b off. I would say swap them small job for ruling something out.
Hahahaha... I obviously didn't think that through!
I might try removing the TB and swapping the injectors around. I'll keep you guys filled in - thanks for the help!
If you want to rule out the headgasket, there is a chemical test you use on the radiator to see if combustion chemicals (namely hydrocarbons) are entering the cooling system.
I've used this on a diesel patrol and it's a good way to easily test instead of removing the head if it is ok.
I got mine from Nissan (test kit). But i Borrowed the tool that screws onto the filler neck for the kit to fit into.
bit like a pressure test tool.
These kits are actually looking for dissolved CO2, not hydrocarbons.
  • Like 1
Update and questions...
Ecu is not my problem - tried a working ecu and it still dropped the cylinder.
Tested coolant for exhaust fumes... The test came back negative for exhaust fumes.
Tested injector driver voltages... Injectors 2-6 have a voltage (on the driver wire) of 14.3-14.7, however injector 1 (which relates to the dropping cylinder) had a voltage of 12.8-13.7.
I have no idea how voltage relates to injector timing and tried to search but found the information was way too technical for me! Does anybody know if this could be causing the cylinder to misfire???
Thanks for the help guys!
Low voltage will increase the latency and reduce the total opening, leading to slightly less fuel in total, but it shouldn't miss that badly. But low voltage static might indicate a bad joint or something that will drop the voltage further when it's under load (ie when the injector coil is earthed and operating).
Injector voltage is critical to their operation so I would be looking further into that. Perhaps the ground side is earthing slightly, which may cause the injector to leak.
I managed to get lucky in the sense that for about 1 minute the car stop misfiring and it gave me time to check that voltage... I've discovered that when the car stopped misfiring the injector voltage went back up to around 14.3-14.7.
It seems as though I've located where the problem is... Now it's a matter of trying to solve it.
I'll keep you guys updated. Cheers :)
I've found my issue - faulty injector. If I give it a few love taps, the voltage rises up to normal and it works fine.
Anyone care to explain why that would be happening (for educational purposes) and is there any home fixes or do I have to replace it?
Yeh I definitely will - don't ever wanna go through the headache again!
Thanks to anybody who contributed to the thread...
For future purposes and research, voltages on the injectors should be checked as it turns out a drop of 0.3 volts can cause a whole cylinder to drop!
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
    • Discover the best Halal food near you with Maharajaonline.com.au. Our delicious selection of Halal dishes will satisfy your cravings and make you feel like royalty. Try us today and experience the difference!   halal food near me
