  • 3 weeks later...
Finish off these clear lenses and get the e85 fuel system and tuned, but i saw a larger hks exhaust housing so tossing up putting that on for the new tune, perhaps not...
Then get either half cage or harness bar so i can finally fit the takata harness i have and also a passenger rail so i can fit the other sparco fixed back i have
what makes you think the stock radiator will give in?
what like, not be enough to handle the heat or just get old and not work properly no more?
Yeah I think the heat gets too much, there really thin and old, mine gave up after a few dyno runs of 320kw.. just got it home, turnt it off and she opened up.
  • 2 months later...
I had my radiator crack at SMSP last month. Really wasn't expecting it to go considering I'm making <200rwkw but it was a hot day..
Yep and mine blew the top tank off it a few months prior to Matts letting go, considering the cost of an engine rebuild i would be doing it ;)
Oh and its also more bling lol
Well ill wait till i can see the budget for a decent koyo rad...
Yep i need to post pics of the indicator lenses installed, they look cool and have wanted to do it for so long..
Do your research on Radiators... I had a choice of Koyo vs PWR vs Racepace and had to learn quite a bit while choosing... Bigger isn't always best ;)
(Thats not what she said :ph34r: )
  • 1 month later...
So im thinking i will have to roll the front guards and maybe a pump if possible to fit 17x9 with 265 rubber, if anyone knows someone to do it on the central coast that would be helpful...
Another track day coming up too, so need to replace clutch and general stuff like oil & filter change, bleed brakes and bleed brakes.
Hope to have temp sensors installed in plenum, turbo exhaust housing to see changes in air temp before and after ceramic coating to all intercooler piping and plenum... If i can get the time to dismantle and and reassemble... Fingers crossed!
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
