Hey guys,
I know that a lot of people have asked this question, but I am still not sure on a couple of things.
When accelerating in any gear, if my right foot is flat it surges/misses (whatever you want to call it) at 4500rpm and agin at around 5000rpm. I have an aftermarket Boost guage, at most rpm it reads ~7psi, when the surging happens (or just before) it reads ~9psi. I can't always get it to hit 9psi only under very heavy load. It then drops down to 0psi and back up again.
Now before everyone says my boost is wound up too high, and that it is hitting the boost limiter/cut - the car is 100% stock. Zorst, i/c, ecu, no BOV and I most definitely haven't change the boost. I have check the engine bay and I can't find a bleed valve or anything out of the ordinary, so I am assuming that it shouldn't be hitting a boost cut.
Someone here mention that it could be spark plugs, I haven't checked them yet.
So does anyone have any ideas on what to do about it. I did think that it might be a crack or something like that in the I/C or piping, but I don't really know. If it is, how do I check it? Where should I be taking boost measurements from
As for the boost cut, the car doesn't perform anywhere near what I would expect it to if it was hitting the limiter. A mates Skyline with a turbosmart DSBC has had his wound up to ~12psi with no worries. Goes a frigging hell of a lot harder (admittable he has an exhaust etc, but still).
In summary is anyone able to give me a run down/checklist of things to do.
Off topic, but who in the Sunny Coast/Brissy area would mind giving me a hand/pointers/demo with the fine art of drift. I know sort of what to do, but until you really experience firsthand it is hard (for me) to put it all together.
Anyway thanks in advance.
Cheers,
Tim
https://www.sau.com.au/forums/topic/4382-boost-cutsurging-etc/
Tim,
I had a similar problem after my car was modified. Under load, at around 4000rpm-5500rpm she'd surge and carry on....after that band of the rev range....she'd pick up again (slowly) and keep going.
I too thought it was my "brand new" spark plugs aswell but in actual fact it was the air flow meters that were buggered.
Your best bet would be to take it to a workshop and have this checked.
After I had some new air flow meters installed......everything was fine ;)
Hope This Helps
If you don't mind me asking, what did you get modified, was that what cause the surging, or was it simply conicidence.
If it is simply the airflow, would it be possible to grab a second hand one from a wrecker. Can anyone confirm this. On a side note I have removed the a/f and cleaned/sprayed it with contact cleaner, but didn't seem to help.
One thing I forgot to mention before was that if it doesn't always happen. On a few occasions it has not surged and has accelerated nicely up to 7000rpm. Sometimes it only surges lightly. I have also noticed that it MIGHT be worse in cold air/at night. Hmmm.
Also when I have whacked in a few hundred bottles of octane boost in the one tank it doesn't seems to happen/be as bad. Not sure though as I have tested this thoroughly yet.
It it timing possibly?
Tim
At that particular time i had bigger dumps fitted.....K&N pod filters and a boost to 16psi. But before then i had a bigger zorst...and all the other sh!t.
When the problem occured....i took the car back to the workshop and they just replaced the air flow meters....free of charge.
Although they said they were gonna try and fix em......so next time i go back...they should be waiting for me.
Hope this helps ;)
Thanks for the replies guys.
At this stage I think I will check/clean/replace my spark plugs first, and then try swappping in a mates a/f metre and see if that does the trick.
With regards to over fuelling, definitely seems to be a possibility, Also makes sense why a stock skyline can only get 200km out of a tank on 98ron and octane boost.
I will investigate a bit further tomorrow and see what happens. If it's no go I think I'll buy a hardcore 180sx and.... nah, not a chance ;)
Dosnt matter what boost im running
and it only started after I de-greaesed the motor.
I have so far sprayed all plugs and conectors with contact cleaner
chacked all the ign coils blocked off the factory boost sensor
re timed the motor checked the cam timing reset the ecu
non of these things have fixed the prob BTW my spark plugs are near new.
anybody with any other suggestions for things to check?
is there a test for the AFM?
Tim if you hold your foot flat dose the motor rev past the problem?
Yeah if I hold my foot flat it enventually gets to like 5800-6000rpm or so and then it is fine until the limiter.
I have been putting in 2 bottles of nulon octane booster every tank and after about 3 tanks it is now drastically better. It still surges but a lot gentler. Damn expensive, but better.
One thing we could try would be swapping a/f metres and seeing what that does.
Tim
Hi Doc,
I have only recently started putting octane booster in, and that has helped immensely.
DAMQIK is currently checking all his electric as he feels thats where the problems lies in his car. If it is we will give it a go on mine.
Cheers,
Tim
PS I do realise that I should bite the bullet and buy new plgus anyway, but at the moment they are all AOK, so I'm hoping I can hold off buying them for a few months
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
