I have for sale an unfinished project. It is registered in NSW till May and completely drivable and reliable. The RB26 engine number is on the papers. Needs paint and some attention to finish off.
The car started out as a GTS-4 sedan. I have swapped the RB20det for an R32 RB26DETT
Interior
Nismo instrument cluster
Personal steering wheel
Nismo white Gearknob
Garrett Boost gauge
Engine
R32 RB26DETT
Tomei Sump baffle
Garrett GT2860-7 Turbochargers
Trust dump pipes
R34 GTR injectors
Splitfire coilpacks and new harness
Aftermarket radiator and thermofan
GTR intercooler and blowoff valves, all stock pipework
All work was done 2009/2010. New timing belt/water pump/ intake and exhaust gaskets etc
Driveline
GTS4 front and rear diffs (Higher ratio than gtr)
Exedy clutch, Nismo clutch pedal bracket and braided line
R32 GTR brakes with slotted rotors, QFM a1rm pads. Braided lines
Nismo Suspension
Rare R32 V-SPEC BBS wheels 17 X 8
What needs doing
The paint is aging, with a few bumps and scratches. The clearcoat has started to lift on the bonnet.
Some rust spots here and there.
Will need a new exhaust soonish, pipe has some rust holes
Engine covers need a repaint
I have the following to go with the car:
GTR fibreglass front bumper with mesh and N1 vents + steel reinforcement
GTR front grill
GTR rear wing
New Nissan oxygen sensors
Replacement pass side rear door
Asking $8500 ono. This car will look incredible with a respray. email [email protected]
Car is located at Seaham NSW
Some pics of the build here, these are from 2010, car has aged slightly, paint has flaked off the engine covers.
http://smg.photobucket.com/user/daver31gtsx/library/HNR32%20GTS4?sort=3&page=1
Edited by Dave R31
https://www.sau.com.au/forums/topic/438230-fs-nsw-r32-gts4-sedan-rb26dett/
Car is still for sale. Note car is at Seaham, north of Newcastle. about 20 mins from the end of the M1/F3
Also should have mentioned car has no airconditioning fitted.
Dave
  • 3 weeks later...
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
