Hey guys, a mate and I are starting a rebuild on his 33. Last engine threw a rod via big end fail, 3 holes in the block and a severely damaged block drifting at QR. M
Want some thoughts on this package, main goals are 300+ kW, it will be a drift/ street car but more drift, he does like to rev it quite hard.
Specs now:
3076 turbs
Wold 3d V500
540 injectors
Front mount
Stainless manifold
Full 3 in exhaust
Split fire coils
Fuel pressure reg, surge tank
Rebuild part list so far ( please give comments and thoughts, nothing is bought yet)
All ports matched to gaskets
N1 pump
New water pump
ARP main and head studs
Cometic gaskets
Cp pistons
Eagle or Manley rods
Tomei Poncams 256
Adj ex gear
Baffled, and larger sump
Oil cooler
All ports will be gasket matched, oil return line and ports enlarged/ cleaned up. Crank balanced, all pistons & rod will be balanced. Block needs to be bored and honed, still unsure about wether it needs to be decked. Any othe suggestions?
Cheers
https://www.sau.com.au/forums/topic/438239-rb25det-engine-rebuild/
Why wouldn't you deck it? It would be at a machinist anyway, and hardly costs anythings to do.
The port matching to gasket is pretty much pointless, typically the gaskets are a reasonable amount larger than the ports, so you would just be doing this
___/\____ (gasket goes between slashes, makes more sense in my head than on the screen)
Hacking shit up and making it worse with a die grinder is easy, improving the flow characteristics of a port is really hard.
If you are fitting an N1 pump and like to sit on the limiter read at least the last third of this thread:
http://www.skylinesaustralia.com/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/?&hl=sk+oil+control
Stay with stock pump or if you want just upgrade the gears in them, Im personally still using stock engine stock oil pump with 350kw last 3 years in my drift car and no problems so they can take the abuse.
Will only deck the block if it needs it, can't see a reason to just deck it. More with the gasket porting is Exh, oil, water. The rb25 heads flow more then enough for what we require. However one of the engine builders recommend it so that's why I was asking here.
Stock pump was trashed and picked up a new n1 for almost free, still looking at changing gears in them. Definitely fitting a crank collar.
Yeah have spent the last couple of days reading that and plan to do sump vent, restrictors and possibly look at .cam cover baffles
Yeah we were thinking of just staying stock, everyone says they are fine at that power but then this is also just ticking the boxes for later, we aren't really doing much headwork yet. That might come later, most probably will.
internal or external gated?
are you planning to stay with 540cc injectors? seems small
Still tossing up going e85 so that will mean complete fuel system change. Also fairly happy to keep 540's in for the run in phase and if it becomes a problem upgrade then. Injectors aren't to bad to change after the fact, it's more bottom end we are focused on ATM.
Internally gated ATM, not sure weather it's worth changing to externally gated, have to do more research.
I'm getting 314AWKW at less than 90% duty on 98 petrol from my 550 Deatschwerks so you should be fine for now.
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
