I'm wondering why in the past few weeks that the GPSs in my possession are out of synch when giving instructions.
Has anyone found this?
Either my iGo, Navman or BMW SatNav tell me to turn earlier than I should by about 10m or they recalibrate their positions after I've turned the corner. Strange.
https://www.sau.com.au/forums/topic/438253-g-p-s-readings/
LOL, if everyone says no, then please dont tell my wife!
Sorry, should have said 'axis' (not 'axis of evil') instead of 'orbit'.
Significant quakes shift the axis alittle each year.
Geophysics has been a hobby of mine for the last 10 years, especially the Pacific Rim.
Anyone can check this stuff out at either:
http://www.usgs.gov/ or http://www.ga.gov.au/
https://www.sau.com.au/forums/topic/438253-g-p-s-readings/#findComment-7183261
So technically then it should also shuffle climate slightly? Make winter colder, summer hotter, or the opposite depending on which way it tilts more. And also "move" the Tropic of Capricorn and Tropic of Cancer yeah? (From memory, and geography is definitely not a strong point, but they're calculated based on the "tilt" of the Earth from memory.)
https://www.sau.com.au/forums/topic/438253-g-p-s-readings/#findComment-7191404
Aww that's a bit harsh Luke ;)
But we trust technology too much!
For instance, there was this time when I sent a letter off to the Civil Aviation Authority asking them to consider two suggestions I had after watching Air Crash Investigations...
1) Cockpits should have a plumb bob to confirm that the ADI readings are in fact accurate or not; in case the plane has gone belly up in the clouds with no horizontal reference and...
2) All aircraft should have a big enough parachute to support itself in case it loses its engines
> Reply suggested that I should be "certified"
> I was stoked; telling all my friends that the CAA felt that I should be "certified" as an engineer but...
> an engineer friend finally took me aside and suggested that the word "certified" was actually in reference to my insanity!
jk
https://www.sau.com.au/forums/topic/438253-g-p-s-readings/#findComment-7196508
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
