Hi folks,
Up for sale I've got the following bits;
1; New Apatronic select (eSel027) plug and play to suit R34 GTT, with vac lines etc. Only opened to look, spec list can be found there http://www.adaptronic.com.au/product/esel027/ - Asking $1,000.
2; A set of 17x9 +22 Advan SA3R with 235/45/17 Federal 595ss - fronts have decent tread and rear are camber worn quite badly, comes with centre caps. Asking $650.
3; Apexi Delta fin turnflow FMIC with engine bay piping, in good condition with joiners and clamps, could use cleaning prior to use. Asking $500.
4; Bosch 044 fuel pump, worked fine before removal. Asking $100.
Price is negotiable on these, can assist with postage at your cost or arrange a meet halfway/deliver for extra $. I'm located in Northern Suburbs Melbourne.
Either PM or SMS on 0498 650 167. Pics to come, or fire me a SMS and I'll MMS pics back.
Cheers
Grant
Bumpity!
Can't upload pics thru the app without crashing. So, SMS me for pics.
Again, I'm negotiable with the pirces as I'd like to move them on.
Hi folks,
1; New Apatronic select (eSel027) plug and play to suit R34 GTT, with vac lines etc. Only opened to look, spec list can be found there http://www.adaptronic.com.au/product/esel027/ - Asking $950.
2; A set of 17x9 +22 Advan SA3R with 235/45/17 Federal 595ss - fronts have decent tread and rear are camber worn quite badly, comes with centre caps. Asking $600.
3; Apexi Delta fin turnflow FMIC with engine bay piping, in good condition with joiners and clamps, could use cleaning prior to use. On hold.
4; Bosch 044 fuel pump, worked fine before removal. Asking $90.
Cheers
Grant
Price adjustment time!
Want them goneski! As usual, will entertain any reasonable offers!
You buy!
Aww man I wish I didn't just buy seats otherwise I would be snapping up that ECU. Retail for $1499 and even with a hypergear discount it would still be $1099
Why u no laybuy?!
Why u no laybuy?!
Aw, poor you.
Can always save up and buy the ECU, or sell the seats :P
whaTever happened to josh...he wanted tris for ages...
I contacted him and he said he was broke.
Photos of the cooler/ price to ship it to 2256 nsw thanks
Cooler is on hold for a mate, will update of its status later this week.
Sorry for late reply - had to talk to mate.
Want a set of BC BR's for a 33 and cash your way?
Um, what am I going to do with something I don't want and have no use for it?
Hahaha sit it in your garage?
:yes:
I've enough shit all over my garage so I'll pass.
Put them up for sale saying you want the ECU.
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
