Hi guys
Can someone give me a 30 second rundown on how to pull the rb25 out of an RA Four stagea?
I need the engine out for body work to be done on the front end
Is it easier to take out the trans with the motor or leave it in? (I don't have to take the box out for the work being done)
Normally I'd disconnect the ecu and pull the loom thru but because of the ABS system it's a butch to pull it thru so I decided to unplug the loom at the engine end.
Basically apart from the obvious stuff (wiring, inter cooler piping etc) how do I go about pulling this thing out?
I need urgent help by the way, I'm writing this while under the car scratching my head
https://www.sau.com.au/forums/topic/438326-stagea-rs-four-engine-removal/
Remove radiator and fan if you haven't already. if you are not going to work on the engine and gearbox and have a decent hoist pull the both out together. Some will say different! If you are going to leave the box in undo the rear mounts so you can lower it to get to the top bell housing bolts. Sorry not much help - had a hard nights work and need sleep! Actually if its an auto probably too many things to disconnect so leave it in,
Hey fellow Kiwi... yeah mate its an Auto 25det... OK sweet think I'll go that way then, and leave the box in the car.... yeah I'm aware of the tilting of the engine etc to undo those top bolts... - I've had comments that re attaching the box is a nightmare? can you advise? - i.e. realigning the box etc.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
