Very nice. Do you have much problem with rust over there, with all the snow?
Thanks :) Snow isnt the problem, but salt used to keep ice out of the road is.. But here in northern Finland they doesnt use it so much :)
^^^ Looks awesome!
I just can't get over seeing an R34 against the quintessential Finnish backdrop ... it's a loooong way from Yokohama :)
Thanks :) Yeah, its isnt the usual backdrop :D
Yeh that's what I was getting at; I had a look under my Opa's car in Germany once. 1997 Audi S4, had so much rust underneath it made me nervous getting in it. Still, beats sliding off the road because they didn't salt it!
Haha :D Luckily i dont drive my r34 at winter. I dont care if my bmw get some rust :D
Looks good.
Front bar is a bit too solid for me.
The division between lip and bar actually helps.
Also with the side all closed up :P
Thanks!
You mean holes in stock gtr lip? I think theres no big benefit of those if you dont have air ducts installed :)
Edited by Guula
Hi Markus,
Love your work. I like the body kit work you have done.
Also appreciated the fact you seem to be majority of the work yourself.
The R34 looks nice smooth. Bet you she loves the cold too ;)
I miss Finland very much and have even been contemplating relocating there, and if do I would take my R32 GTR with me.
Will keep an eye out on this thread.
Top stuff
Hi Markus,
Top stuff
Thanks mate! :)
recon you should shave the door handles !
My friend said the same :D But im not going to go there now, maybe later if repaint the car etc..
I just drove little 1300km road trip and next thing is raise the boost 0.7 -> 1.2-1.3 and tune it :) Turbo and new screamer are awesome!
  • 4 weeks later...
Like to see a DIY on making that front lip?
I have to check how much i have photos of making it :)
How did you go, any dyno results yet?
Hope to get it tuned next week.
My clutch release bearing started to make some noise so had to repair it week ago.
Also replaced all bushes from rear. Much more solid rear now :)
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
    • ChatGPT is trash and lies about things I would not expect it to lie about considering many things it's wrong about are very easily verified with google. The S3 R33 GTR shares its steering wheel with R33 GTSTs of the same production year. Part number is 48430-26U17. I'm guessing you have to get it from a car that came with HICAS though, the ER33 is 48430-26U18, but the HR33 diagrams note that part number is still leather vs 48430-26U13 which is not leather-wrapped. They all use the same airbags, so if you need another one you can get it off basically any same year R33 or Stagea.
    • I'm going to run hard lines front to back in the future. That should help dissipate a bit more heat. If not, a fuel cooler might be next
