And what would you expect the plugs to look like on ethanol anyway? The shit would evaporate before you got the plug out. It's hard enough to read plugs on petrol since all the lead was removed.
Plugs looked fine, and were not causing misfire. No melting, or signs of DET damage.
The DET was picked up with a knockbox setup that Trent has been proficient with for 5+ years, I am sure he has heard more knock than any of us... Amplified 100 times over. :P
Very hard to prove without climbing into the cylinder at full noise. Considering the engine is brand new, I doubt there is any carbon buildup causing pre ignition, sharp edges in the quench perhaps, but I don't think Tony wants to rip the head off unless all other avenues are exhausted. (Plus we need to give the engine builder the benefit of the doubt, I am sure he knows what he is doing.)
What other causes of pre-ignition can be ruled out with the head on? Remember, this is happening on ethanol and 98...
More often then not its something stupidly simple....
How about the water temp sensor? Could that play a role in perhaps a timing correction table based on what temps or something??
highly doubt that is, Trent will know straight away.. you will see it in Nistune if the temp correction table is used as it lights up green.
I would recommend plugging up an EGT into each runner (one at a time I guess to keep cost down) and data log the EGT per cylinder for the same run/conditions 6x times - this would still be cheaper than pulling a head off
what about the effect of having a polished ported intake side, apparently this can be a bad thing and cause knock?
"The carburetor or the fuel injectors spray fuel droplets into the air in the manifold. Due to electrostatic forces some of the fuel will form into pools along the walls of the manifold, or may converge into larger droplets in the air. Both actions are undesirable because they create inconsistencies in the air-fuel ratio. Turbulence in the intake causes forces of uneven proportions in varying vectors to be applied to the fuel, aiding in atomization. Better atomization allows for a more complete burn of all the fuel and helps reduce engine knock by enlarging the flame front. To achieve this turbulence it is a common practice to leave the surfaces of the intake and intake ports in the cylinder head rough and unpolished."
picture of the droplets in my manifold i saw when removed
Edited by AngryRB
I would start back at basics.
Throw in another set of injectors or get the old ones flow tested, one lazy one and its DET city.
Make sure none of the injector wiring is a issue, right back to the ECU plug, one injector not opening enough or long enough will lean out the engine on one cylinder, enough to cause det so check wiring and plugs.
Run a test with 1 or 2 heat ranges cooler spark plugs, see what it does after the injectors have been tested, dont just test with another set of plugs of the same heat range, issue could be cylinder temps, im guessing there is no EGT probe.
    • I mean this in no disrespect to u mate; Are there clear tagged examples/explanations in our SAU forum for example, in my interest, this is how to do R34 Gtt suspension the right way? U guys did so much taking risks with experimentation that deserves recognition and those results helps us morons take the RIGHT path to buy quality / buy once. 🍻
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
