Glad to see this is resolved, I have been watching with great interest.
Today I was having a think and felt worried about the issue occurring on more peoples cars than we would like, and ultimate I came to the conclusion that we are a little stuck when we go for poverty pack Nistune boards.
I am just wondering and thinking aloud, has anyone ever tried to run a different trigger system on their Nistune? Such as a crank trigger or similar? I would REALLY like to know if this is at all possible. Perhaps a call to the Nistune dude in SA is necessary, as I am sure something simple can be written into the code.
Trent and I were discussing this very topic yesterday after seeing the fault first hand. We agreed the later (VQ etc) motors using a flywheel based trigger with a large trigger wheel behind the starter teeth was a much better idea, as the larger the wheel, the easier it is to pick up the trigger magnetically, hence less noise. Not sure how hard it would be to make something like that work on the RB flywheel though.
As for the stock cas, the spacing is just too small between the cutouts for a lagging optical sensor to pick up. That said, they are very old by now and most probably require replacement. Any idea how much they sell for new?
I wonder how hard it would be to modify the stock harmonic balancer for a trigger wheel? All it needs is a 24 tooth chain sprocket tapped on to it with one tooth ground down, correct? But you would still require the converter box for the Nistune.
I'm just being funny about the pov pack, its definitely the cheapest option is all. I'd run it over a lot of other aftermarket units, but would rather run a Link or Adaptronic for that matter. Money talks :)
XKLABA do you mind telling me who makes the converter box? Is it also Ross? I agree if the PFC can do it, the Nistune can, too. How do you find it works?
That's a shame the trace didn't show it up? was that using nistune to log it? Perhaps the sample rate isn't fast enough, as you know everything is happening extremely fast!
It doesnt show up in any ecu in the log.
:D Yeah, the ECU doesn't know any more than the CAS is telling it in terms of where the crank position is. The ECU will do it's normal calculation on advance and record that in the log, the best chance of spotting a triggering issue is if the ECU is smart enough to realise it has not recorded a trigger in the period of time it should have and then logged it as a warning.... or if a triggering is bad enough the deviation in the logged rpm "curve" has the potential to get quite conspicuous.
Thanks for the feedback, shame you didn't get to use it with the PFC!
Your welcome, it may end up on the 32 yet, with a 36-2 CAS disc and the PFC if I don't bit the bullit and get an EmTron
Paul had it on his car with the link using the nissan signal before getting the M3 put in, he might be able to shed some light on this
I thought it might have shown up as erratic timing being delivered in the nistune log. Obviously best chioce is using a scope to log it.
One of the joys of paying big money of a ECU is the Syvecs has a built in 1khz oscilloscope, which was instrumental in finding a sensor issue I had with the Ross setup
The two lines on the graph are with filter and without
Shame we didn't test the airbox closed with no filter, just with the lid off and no filter, (mainly as the filter kept popping out on decel.) The filter was dirty, though I suspect the snorkel holds power back a bit. Stao has drilled lots of holes in the lid of his which obviously works.
    • I don't like "actual computers" for in car use. They take time to boot up, have OS annoyances, and so on. Arduinos etc are ready to go a few seconds after power on, don't mind being agressively powere cycled, because everything is non-volatile, don't mind being shaken and stirred.
    • As Fred would tell us, it's all about interpreting the rules. It's not a water sprayer, it's a water mister... But everything else you've said, 100%! Even a raspberry Pi would be great, use HDMI out for a display, and add a raspberry Pi CANBus hat to read values out from the ECU.
    • Being a race car, and being in the era of the Arduino, one would think it would take little effort to build a controller to do the spraying based on a real physical measurment. Waaaaay back in the dim dark AS days, JE "designed" (as in, he had help) a microcontroller based intercooler spray system. It watched the difference between a temp sensor stuck on the core and one in the free air in front of the cooler, and if the temperature difference exceeded a (settable) threshold, it would activate the sprays. Thus, it only ran water when there was an actual need for water. If you stop to think about the actual physical things that are going on in that stack of coolers, there's probably at least a couple of triggering conditions one could come up with, and one could probably even run one pump with more than one solenoid valve, to allow water to be placed where it is needed, or at all points at once (if it is needed at all points). We're in the age of science baby. But.... I suspect that intercooler water sprays are on the forbidden list in most circuit classes, no? So only good for Targa type stuff?
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
