1990 BMW e34 535i with a 3.5 Litre engine
Was told the engine has been rebuilt 20,000k's ago, nothing to prove this but it really does run fantastic, has 360,000 on the ODO.
It is automatic and has full leather interior (small tear on drivers seat)
Sunroof that works.
Currently on black Inovit 18 inch rims with good thread on the tyres. Will also come with stock 15inch rims aswell
Body is in great condition, only a scratch just behind drivers door.
Has dark tinted windows, and a head unit that plays Cd's (can't remember the brand of top of my head)
CONS- Only negative is a oil leak from rocker cover (cheap to fix but very common problem, will happily get it fixed for the right price )
I am willing to swap for a turbo 180sx, s13, s14, r32 or r33 skyline, 300zx or something similar (can throw some money on top of the trade if your car is worth more then the bmw). Let me know, just shoot me a text, worst I can say is no.
Car located south eastern suburbs of Victoria. Would be able to be driven away with a vehicle permit.
Genuine reason for selling, just send me a text for any more information.
The car will not come with a rw or rego (can be negotiated for an additional price)
Currently after $3,500 but I am open to offers, once again worst I can say is no.
Number is 0430 354 983 - preferably send me a text for enquiry.
Thanks for looking.
https://www.sau.com.au/forums/topic/438377-vic-fs-or-swap-bmw-1990-535i-e34/
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
