2003 Nissan Stagea M35 Autech
2003 Nissan Stagea AXIS AUTECH, 2.5ltr V6 TURBO, tip tronic 5sp auto, ATESSA All Wheel Drive, All Autech options.
This car represents great value at $17,990.
Engine - VQ25DET - Power - 209kW @ 6400rpm - Torque - 407Nm @ 3200rpm
Reasonable Offers Considered.
I have really enjoyed driving this car however it is now time to sell as I am moving overseas. This Nissan Stagea has a full service history available. Check out this well maintained car, always garaged and looked after meticulously. Genuine 120,00kms with the car having been in Australia over 2 years.
Registration has been paid until January 2015.
- The previous owner/importer of this vehicle had all the leather re-trimmed in a high quality off-white/ tan coloured leather which looks amazing compared to the factory trim.
- GPS fixed to work in Australia along with translation of the computers menu from Japanese to English.
- Reverse camera installed.
- HKS coilovers fitted and guards rolled.
- Reverse Light covers (pictured) Regularly serviced, well looked after and will be extremely missed.
PICTURES
Edited by 180boi
  • 3 weeks later...
  • 1 month later...
 Share
    • Pretty simple question. I was about to put the transmission back in and thought I pretty much had it lined up when I noticed it seems like the pressure plate isn't flat. I was pretty careful when undoing the bolts both during initial disassembly for cleaning and when torquing them up for installation so this is pretty discouraging. I'm not sure if I accidentally bumped the pressure plate with the input shaft and bent it somehow or if it just showed up this way. Is it possible that there's just something obvious I'm not doing correctly? I'm pretty sure I was extremely careful to make sure the friction discs were seated correctly in the hub, everything lined up, flywheel torqued according to sequence, the little springs all sitting correctly in their seats, etc.  What's the play here? Do I jump straight to a new pressure plate?
    • OK. I can see that being the case. But if you live in the land of "only switching between 4.08, 4.11, 4.36" like most Skyliners, then you never encounter it. Now I perhaps understand why the crownwheel is thicker on some of the smaller numerical ratio diffs. The two stubs being the same (unequal) lengths and just swapped side to side between the different cases is a new one to me. I'm hating Nissan R200s more than ever now.
    • Reason I say this is I have seen broken ones, in drift, drag and even behind a stock Z. I do appreciate most of the time its the synchro's that go.   Trouble with quoting HP is it doesn't really say how strong the box is.  I've not seen many CD00X box's make it past a mid 9(150mph) I have seen about a stock R33 RB25 box's run a 9 too, they all go boom at some point though.   Another clue is they make gearsets for CD00X box's too, wouldn't be a market if they didn't break or have a limit people are going past.   I totally agree it is a strong box, just have to weigh up the true total cost of the conversion vs rebuilding with a good gearset.
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
