I fitted some Defi gauges a little while back with the intention of fitting an oil cooler but never got around to doing so and felt if my temps (with light track work) never got too bad I wouldn't worry with the cooler. But as the factory Nissan temp sensor is M12 x1.25 thread and the defi sensor is 1/8NPT I could never fit the temp sender and effectively had a useless gauge. I spent ages trying to find an adapter through just about every gauge, fitting, performance site and store within Australia and could only come up with suppliers from the UK with shipping worth more than I could justify. I could find adapters that were M12 x 1.50 and M12 x 1.00 but not 1.25 as it's a very odd size.
Finally I found a local supplier on ebay that sells them - http://www.ebay.com.au/itm/Metric-Male-M12x1-25-To-Female-1-8-NPT-Also-Use-For-Pfira03-Fitting-/151195760051?pt=AU_Car_Parts_Accessories&hash=item2333f835b3
All I did was fit an o-ring around the M12 thread that goes into the factory oil temp sensor location to seal it up (thread sealant would do the same but I didn't have any) and thread tape around the Defi sensor. I was a bit worried as the sensor tip did not stick out a great deal from the end of the adapter and not getting a true reading but the adaptor looks to thead in just as far as the factory sender and after taking my car for a run it seemed to work near spot on.
The temps warmed up relatively similar and after a good freeway run with 30degree ambient temps in Adelaide the oil temp was within 5 deg C to the coolant temp which is what I expected to see.
Yeah I have a gtt and see link to photo of the sensors location on the oil filter housing with the adaptor in place, the hot engine bay made it hard to get in closer lol
http://www.use.com/supersize.pl?set=3703df3839032c6a08eb
Edit: Sorry, you said it was M12 thread, I thought it might have been the stock oil pressure sensor but with that thread I dont think it can be, pretty sure Nissan used the same 1/8 sensor for all Skylines
Edited by 89CAL
Yeah the oil pressure is 1/8th NPT but the temp is M12 x1.25, Blitz make a similar product but as I said rather buy Australian if possible
http://www.fqperformance.com/shop/product_info.php?manufacturers_id=20&products_id=876&osCsid=ezhimmjjeyco
There is an easy way for rb 20
Dunno if rb25 is the same
I decided that the sensor is going to get pretty good accuracy, but take an extra 2 or 3 seconds for the temp to get there.
Fluids are good at transferring heat. Even though its not in the stream of oil, it works very well.
Edited by D.I.Y. Mik
I remote mounted my 2 oil pressure sensors. Just used a -4 braided line (I think it was -4 or -3) and put a fitting in the block and a T piece and the 2 sensors up the top. Pretty much the same as above, but remote mounting it for easier access. Probably not as good for oil temp, but works for oil pressure
Yeah havent had any problems with strange oil pressure readings. They are pretty much spot on where I would expect them to be.
Originally was going to just tee it off the block but this seemed smarter in case anything ever went wrong its so easy to fix :)
I've painted everything since then so its all black now bar the braided line, can just see it in this photo, it blends in pretty well now
    • Are there any wiring looms that weren't swapped? Were all the dash looms changed etc?
    • OK, so all I can suggest is that - if you have all the parts, and you have all the wiring looms, and you have all the electronic modules, then....it really is just a wiring problem. You likely have a damaged wire, pin, etc, somewhere.
    • Yup, bought this bad boy and hopefully it will be ready to pickup today. Had $5 credit on top of it so it worked out really well!
    • Yeah it is really until until you get a feel for it....then it is easy. Which is no use to you really. I'd buy that torque wrench. One thing from sure, many (most?) tyre shots overtighten the f**k out of wheel nuts, so don't worry if they were tighter when you tried to take them off compared to when you do them up. I've had some crazy tight ones come back from shops, quite apart from the potential damage to the thread, I can't see a smaller person taking the wheel off on the side of the road
    • Hey mate, thread dredging hahah To answer you directly, yes I had my itbs oversized and custom butterflies etc made by EFI Hardware in Sydney back around 2017-2018 if memory serves. My setup had a vast amount of other changes too though, so no direct comparisons unfortunately. i went from oem itbs, HPI manifold and internal gate hks 2835 pro S; to 49mm itbs, cnc port matched Nismo plenum, RB25 Neo lower runner adapter hand port matched, r31house v2 Takoashi MAX equal length twin scroll manifold with twin 38mm tial gates and a FP HTA3076 with 1.01ar twin scroll real hosing. feom power Fc to a link fury wired by 12volt, r32 gtr fuel tank conversion with frenchys twin 460 / surge tabk fuel hanger combo kit, 1659cc injectors, full 4 inch turbo back stainless exhaust, Z34 6 speed, Tomei 2way with 4.3 final drive and a ton of other shit. ive posted elsewhere here with complete run down, but here's a graph from its initial tune with no boost control on, 20psi gate springs only and e85.   7542AE72-DA92-4E0B-8660-B0940FEA7F24.mov
