I fitted some Defi gauges a little while back with the intention of fitting an oil cooler but never got around to doing so and felt if my temps (with light track work) never got too bad I wouldn't worry with the cooler. But as the factory Nissan temp sensor is M12 x1.25 thread and the defi sensor is 1/8NPT I could never fit the temp sender and effectively had a useless gauge. I spent ages trying to find an adapter through just about every gauge, fitting, performance site and store within Australia and could only come up with suppliers from the UK with shipping worth more than I could justify. I could find adapters that were M12 x 1.50 and M12 x 1.00 but not 1.25 as it's a very odd size.
Finally I found a local supplier on ebay that sells them - http://www.ebay.com.au/itm/Metric-Male-M12x1-25-To-Female-1-8-NPT-Also-Use-For-Pfira03-Fitting-/151195760051?pt=AU_Car_Parts_Accessories&hash=item2333f835b3
All I did was fit an o-ring around the M12 thread that goes into the factory oil temp sensor location to seal it up (thread sealant would do the same but I didn't have any) and thread tape around the Defi sensor. I was a bit worried as the sensor tip did not stick out a great deal from the end of the adapter and not getting a true reading but the adaptor looks to thead in just as far as the factory sender and after taking my car for a run it seemed to work near spot on.
The temps warmed up relatively similar and after a good freeway run with 30degree ambient temps in Adelaide the oil temp was within 5 deg C to the coolant temp which is what I expected to see.
Yeah I have a gtt and see link to photo of the sensors location on the oil filter housing with the adaptor in place, the hot engine bay made it hard to get in closer lol
http://www.use.com/supersize.pl?set=3703df3839032c6a08eb
Edit: Sorry, you said it was M12 thread, I thought it might have been the stock oil pressure sensor but with that thread I dont think it can be, pretty sure Nissan used the same 1/8 sensor for all Skylines
Edited by 89CAL
Yeah the oil pressure is 1/8th NPT but the temp is M12 x1.25, Blitz make a similar product but as I said rather buy Australian if possible
http://www.fqperformance.com/shop/product_info.php?manufacturers_id=20&products_id=876&osCsid=ezhimmjjeyco
There is an easy way for rb 20
Dunno if rb25 is the same
I decided that the sensor is going to get pretty good accuracy, but take an extra 2 or 3 seconds for the temp to get there.
Fluids are good at transferring heat. Even though its not in the stream of oil, it works very well.
Edited by D.I.Y. Mik
I remote mounted my 2 oil pressure sensors. Just used a -4 braided line (I think it was -4 or -3) and put a fitting in the block and a T piece and the 2 sensors up the top. Pretty much the same as above, but remote mounting it for easier access. Probably not as good for oil temp, but works for oil pressure
Yeah havent had any problems with strange oil pressure readings. They are pretty much spot on where I would expect them to be.
Originally was going to just tee it off the block but this seemed smarter in case anything ever went wrong its so easy to fix :)
I've painted everything since then so its all black now bar the braided line, can just see it in this photo, it blends in pretty well now
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
    • I would suggest equally difficult to find, perhaps edging to the SR. Turkey has almost exclusively Euro market cars, some Korean, few Japanese other than pedestrian shite. I guess they're probably losing the fight against Chinese shit like we are now too. I would vote for a BMW V8, found in a 540i in a wrecking yard somewhere in Deutschland (or possibly Albania).
    • A CigWeld EasyWeld 130 can be had from ebay for $360 delivered. Good for 0.6 to 6mm, which would be fine for my requirements. I guess that on top of that you would need to buy a regulator, hoses and wire. I already have gloves and an auto-darkening mask. How is the gas bottle charged? Do you rent it then pay for top ups?
    • RB20 being an option from factory would mean no custom parts or fabrication required, just have to collect the right bits. Probably would be the easiest option I reckon for a motor swap. How common are SR20s vs RBs in Turkey?
