Hi All,
I thought I would introduce myself, the names Nick and I've recently purchased a White Stagea Series 2 RS4S. Will post pics soon!
I purchased this car late last year off Indy as IS Motor Racing, I've known Indy for a long time as he helped me build and tune my old Evo 8MR.
When I picked up the Stagea it was close to stock bar a few small mods r34 GTT brakes and wheels, Cusco coilovers, HKS catback and rear camber arms (unknown brand). I couldn't just leave it like this so I started modding straight away.
So far I have changed the front and rear sways + links to whiteline items and Indicators to Nismo smoked type.
I have also purchased a few other bits n' bobs I'm currently fitting or modifying:
Factory electric Leather seats which I'm in the process of wiring in - no loom on the RS4S for this unfortunately (Fairly easy job to fix anyway) Will take photos of the process and post DIY.
HDI FMIC kit - need to have an exhaust shop make up another pipe so I don't have to cut under the battery tray. - Any recommendations where to get this done in Sydney?
3" dump pipe
3" cat - spare off my old evo, need to get an exhaust shop cut and re-weld the flanges
DAYZ front bumper - I have cut out the numberplate mount and the vertical running supports to give it a wide mouth look and I am now in the process of cleaning up the holes left by these by filling with fibreglass, I have been taking photos of the process and will provide DIY once finished.
Also since buying the Stagea I have cleaned up the yellowing headlights, and given it a good detail - which was subsequently ruined the next day when it rained "typical".
After all this is done the next job is removing that pesky HICAS using a Driftworks HICAS removal kit and get some wheels without the weak offset and width of the GTT wheels. For a wagon especially after coming from a Evo I'm quite surprised how well it handles.
https://www.sau.com.au/forums/topic/438419-2000-stagea-rs4s-owner/
  • 4 weeks later...
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
